Hola SEnor
ya you will fill a bucking surging cutting out when you are injecting to much.mm-kk i will give it hell.. ill start off smaller like you were sayin... working up.. QUESTION-- reading your posts your sayin it acltually cut the engin out?? so i will definatly know when im to big and to bring it down a little bit.... thanks
For sure..... I had the same problem one time. Don't be to alaramed though because it might scare ya for a split second.ya you will fill a bucking surging cutting out when you are injecting to much.
ok.. cool thanks.... question??? just currious as to what size nozzle or nozzles did you end up running the best on?????? after you went to big?? thanks againFor sure..... I had the same problem one time. Don't be to alaramed though because it might scare ya for a split second.
I had stock injectors and with a ok programer and mine was bucking and surging pretty bad....Man that scared me when it happened.
Man it's been so long ago since I have done that I can't remember. But here was my problem. I had it firing everything it could at about 20lbs of boost and thats what was causing the issue.........ok.. cool thanks.... question??? just currious as to what size nozzle or nozzles did you end up running the best on?????? after you went to big?? thanks again
ok.... cool thanks for the info....Man it's been so long ago since I have done that I can't remember. But here was my problem. I had it firing everything it could at about 20lbs of boost and thats what was causing the issue.........
Make sure that whatever you decide to spray it's almost at max boost... Like if you're making 45lbs....Try to set it to like 40lbs
