just a few quick ???s bout a water/methanol injection. one how does it work???? two is it worth the money to get it or should i kinda stick to the basics. i have a fass ddrp, edge comp box, k & n air filter. looking into jammer injectors mrbp 4" switching to afe stage 2 air filter and a banks intake manifold. if anyone can help me out with this then plz do
I dont think it would really be worth it intill you get a bigger turbo and injectors. Its saposta cool egts down 200-300* and gain 40-60 HP. Im going to do it once I get my 64/71/14 turbo and my injectors but personally I wouldnt do it with the stock turbo. But you definently could do it wouldnt hurt anything :thumbsup:
it works by reading boost pressure, then spraying the water/meth at your pre set intervals. mine starts to open at 20psi and goes wide open at 30psi.
i got mine because of price. i got a snow stage 2, 7gal tank, and solenoid, for $400. it lowers my egt's 250+*. with just my 200's and water/meth (on a hx35) my egt's wouldnt get over 1400*. without, the egts would climb 1600+*.
if i were you, id get some more gauges. (egt/boost/tranny).
depending on if you had a manual or auto tranny would dictate my next move after that.
ok what bout injectors with my stock turbo will it be good idea to run 100hp fbd injectors. also anyone know anything bout Banks Power Quick-Turbo Assembly w/ Wastegate Actuator???? looking into it but not sure. just looking for more power
yeah 100 hp sticks will be fine. Im not a big fan of the banks products but have never used the turbo.
i spary into my stock hx35 just fine :thumbsup:
imo. use what you got till you want to upgrade to a bigger turbo.
