1 - 20 of 20 Posts
hey guys i have a 02 1-ton and it's always hooked to the trailer, heard that the water/meth treatment is a easy and half way safe power allternative. looks confusing to me on setting up everything though. any suggestions on wether it's a good idea for a farm truck with heavy loads all the time or any pro's & con's to using something like this.
thanks
i've done a lot of reading on this and it seems the water/meth is great for towing. i too tow 5 days a week,and will be getting some 100 sticks in the next couple weeks. the water/meth will be very soon after to keep my egts down.
its very easy to set up or at least my snow performance kit was. Very straight forward install. I hardly ever tow so i wouldnt know how much it helps just drag racing and messing around it lowers my egts by about 150-200 degrees
PM Rollin Coal. He built his own water/meth system and said it worked great. I believe he is looking to sell. Give him a shout and see what he did.
Eric
Just be careful how much you are injecting and how much methanol your mixture contains
I've been told no. And I believe most people that run water/meth on a daily setup just use regular washer fluid.
Eric
Hemi
If you ran straight water wouldn't it just cool and not add any power? And I'm sure the nozzles are sized so that I can't add too much.....
Yes the water will just be a cooling effect.
Discussion Starter #10
and just so i get this right you can adjust the water/meth setups to how moch is added or is all you can change is ratio of the water to meth %
i just started reading up on this, thought it might be a way to add power as compared to a chip or programmer
i'm either going to run water/meth or edge juice w/additude, just seeing what some experiences have been with water/meth systems
Discussion Starter #11
anybody else have any ideas or luck running water meth on a towing vehicle. and what kind of power increase is common
Hemi
You will see much more from a programmer/box but it will get warmer also while towing.
I seen a gain of 40hp on the dyno with just washer fluid.I run 50/50 now,but have not been able to get back on the dyno because our dyno days keeps getting rained out
I've been told straight water adds 25-40 hp because of the steaming effect inside the cylinder. IMO, it's pretty safe if you don't run high methanol concentrations (above 33%).
Putting on a "mileage" programmer will bump the timing and actually decrease EGTs while also giving you a few ponies. Just a thought.
Advanced Auto -20 below.Im going to run 60m/40w when i get back on the dyno
hey smokinfords do you just run straight washer fluid or do you water it down as well?
straight washer fluid is just fine..the advance auto -20 and the auto guard -20 fluid is already a mix that is close to 60-70%water. right now im running a bottle of washer fluid and one bottle of heet gas treatment which is 99%meth.for a 40%by weight meth. or 47%meth by volume. it seems to work well. But on dyno..if it doesnt get rained out. im doing a higher meth mix aswell.
I agree, just washer fluid will be fine.My samurai if you want some meth,i can get it locally
1 - 20 of 20 Posts
