1 - 3 of 3 Posts
I have a question regarding Water In Fuel light on dash.. Whenever it's wet outside (rain, snow, etc.) my light will come on and I drain it from the Water Separator on my FASS 150. Yet the light won't go off and after I finish running the engine again, the Water Separator has as much water in it as it did when I drained it before. Anyone know whats up?
The water in fuel sensor was on the factory fuel canister which I believe gets removed or bypassed when you insall the Fass 150. If you still have the factory canister and it is just bypassed you might have water up there. And as far as draining the fass and it having water in it alot I would say you picked up some bad fuel somewhere that has a lot of water in it or your fuel cap has a leak. :thumbsup:
Thanks alot, turned out I got crappy fuel.
1 - 3 of 3 Posts
