I have been in the process of designing a water cooling system for cooling down the VP44's computer. I plan on this design to act as a heat sink to pull heat away from the computer. I am aware that the fuel cools the computer down! The reason why I am planning a water cooling system is because I want to pull heat from the computer while the engine is off and under hood temps are high. Once the computer temp reaches a lower tempature the pump will shut off and the heatsink would be complete. The purpose for this system it to make the VP44 electronics last longer by reducing heat cycles. The system would intel a water pump, ECU water block, cooling fan/radiator and, water tank.
