Did you go make them rotate them like you paid for?
I did. I didn't notice they weren't noticed until about an hour later. Lucky for me I was across the street at Costco.Did you go make them rotate them like you paid for?
Good point. I'm gonna start marking the filters and even the differential drain plugs to make sure the work is actually done.My dad.....6.7 powerstroke guy had to start marking his own oil filters, because 2 instances they drained the oil, added new and didn't change the filter.
Always good practice if you're taking it anywhere.Good point. I'm gonna start marking the filters and even the differential drain plugs to make sure the work is actually done.
Because it's SOOO hard to remember if you swapped around 4 or 5 relatively heavy wheels/tiresThe service writer called the tech and asked if the tires were rotated. The answer I got was "he believed he did".
