1 - 2 of 2 Posts
Im in the middle of putting my 62mm s300 on as a single. the wastegate actuator has a nipple for the rubber line, im assuming this gets fed back into the inlet? theres some type of port there but its plugged with a bolt. also what about the factory wastegate solenoid? can i unscrew it from the inlet and ziptie it up plugged in? thanks
1 - 2 of 2 Posts
