1 - 11 of 11 Posts
I have a power puck and can I stack a max mileage with it
Has anyone tried this yet
not sure what a max mileage is, but the puck just ups rail pressure. If the max mileage is pressure box, then no go.
Never heard of a box that only does timing. I would confirm that
hydraulic lifter crew
i would double confirm what quad told you too :stirpot:
rule of thumb is to stack one box that does fuel
onto one box that done timing / pressure. your
messing with fire if you try two of the same.
Discussion Starter #9
There on eBay all the time but I'll call quadzilla again to make sure
Must be a typo
Fuel and pressure are considered the same. I believe what you meant to say was stack a fuel pressure box with a box or programmer that does both timing and duration.
1 - 11 of 11 Posts
