1 - 20 of 30 Posts
Getting ready to start ordering stuff for the new engine. Need to know what kind of pistons? how much will the rods hold? 60# spring work? What kind fuel pump? 12mm or 14mm studs?
going to be running around 700hp on big single turbo.
dont we all want 700hp......
i wish i had the money for it :(
Tech Specialist
Pistons: stock or marine for 25*+ timing or 370s
Rods: stock will hold 1000+
60lbs VS should be enough
12mm pump set to 400cc will be enough
Go 12mm studs, 625s if youre worried. 14s aren't that much better, and some have problems with how they are cut, they need to be drilled and tapped really well
Get a P&P'd head
that much power should be interesting in a 2wd
will o-rings hold the a5k or do i need fire rings? and how much boost does a a5k push?
well mine isnt a 12v so maybe different worlds but it makes around 50-60 psi of boost. some guys can make 65/70 with them but they dont live long. if you have the fuel it will make the power you want trust me :thumbsup
THE Hood Stack Guy!
A5000 is somewere in the 50 range. Good turbo for that power level but a little too pricy for me. I have the same size whell and mine has mande 856 so it should be able to get you there. looks like everyone has gooten you some great ideas to get you there.
If your going to run a single, I would say you might want to look into a water/meth set up. It will help keep the motor cool and gain you some power! They are relitivly simple and worth the money.
I think fire rings would be a good idea just because it realy not that much more to get them.
Good luck and keep us posted!
1 - 20 of 30 Posts
