1994 12 valve Cummins
Zf5 transmission
188/220 cam
Head studs
Beehive valve springs
Extreme duty push rods
66/66 silver bullet turbo
Rack plug
191 delivery valves
5x20 injectors
Fass 240 fuel pump
5 inch straight pipe exhaust
Dual disk south bend clutch
Dana 60 kingpin in the front
Sterling 10.25 in the rear
4.10 gears
I want to go to a compound set up instead of the big single . What set up should I use ?
Vendor
Thanks for the list of mods.
What is your goal for HP? How will you use the truck? Do you tow heavy and often? are you willing to give up a little top end power to get better response?
66/s480-- support 800-850HP...faster spool up once moving and less smoke than you currently have.
If you want to support a little more power than you have now a 62/s475 will support 750HP (configuration of the 62mm will depend on how you plan to use the truck)
What direction are you leaning?
This is a fummins truck 1977 f250 that only gets driven once and a blue moon. Goal off 650-700 hp range .
