i want to get power to both rear tires because this truck sucks in the snow i want it to be the factory type set up i dont want it to be a nuisance to drive on the road. i have 307 gears. where would i find an lsd carrier??
arent those really harsh on the road for normal driving?You can also get a powertrax lock right that replaces the spider gears. I had one in my old Chevy front axle, I really liked it.
what is the difference? i am not very familiar with any of this. is one more reliable or easier to install?POSI & LIMITED SLIP
Your axle is most likely is a 35 spline. But pull one axle and count the splines. I have heard of one 3:07 that was 32 spline. You don't want to buy a L/S without knowing the spline count. Remember they will hit you with a restocking fee if you get the wrong carrier.
Both of your links show the old one piece carriers. The link I posted is the newer two piece carriers. I have delt with that company many times over the decades.
Both styes require the same for install. If you have to buy a new one. Buy the current design. It makes getting rebuild parts easyer later on during the life of the L/S.what is the difference? i am not very familiar with any of this. is one more reliable or easier to install?
I drive mine every day. I like it.arent those really harsh on the road for normal driving?
The power trax is noisy you will hear a clicking noise when you turn, it replaces the spider gears.what is the difference? i am not very familiar with any of this. is one more reliable or easier to install?
it does not interfere with tight turning? i am making tight turns fairly often manuvering trailer or other whatnot. i could care less about noise my exhaust barely goes past the cab noise dosent bother me its driveability i care aboutThe power trax is noisy you will hear a clicking noise when you turn, it replaces the spider gears.
Was it mine? As mine is 3.07 with 32 spline shafts...I have heard of one 3:07 that was 32 spline
