Like the title says, my wait to start light is always coming on and then once it goes off, the light will flash for few seconds then goes solid. I replaced the grid heater solenoid a few months ago because I was getting a low/no voltage drop across the grid heater code, that solved that problem, now this new one, I have no codes, checked with the on/off method and also with my smarty. Something is wrong. sensor? ecm? pcm? don't understand. I also checked the volts coming to the grid heater relay and all I am getting is 4.6 volts roughly, should it be 12? I have searched high and low and have found no helpful info yet, anybody? thanks
