Need some opinions and I'll try to keep it short,
Truck: 1999 Dodge Ram 3500 5.9l turbo Auto 2WD. Truck hasn't ran since I bought it
Lift pump was bad so I replaced it with another stock unit (Didn't realize I shoulda upgraded but here we are).
Added a fuse/relay to the pump that uses the signal from the ECM to activate.
Re-terminated the battery cables and grounds going to both batteries with military style connectors due to voltage issues and poor fitment.
Went through any grounds under the hood that I could get easy access too and cleaned/greased em (still need to check passenger side motor and driver side ground by starter)
Pulled ECM out to clean contacts to motor and re-installed
I'm currently pulling both p1688 and p1689 codes ( and p0230 but that's the lift pump wiring), so from what I've gathered the VP44 is toast. But the weird part is how the truck is acting. If I have the relay for both the injection pump and lift pump installed, the lift pump will not run. If I remove the relay for the injection pump, the lift pump functions as it should (short bump on ignition and runs for 25ish seconds if starter is bumped). I get good signal voltage to the injection pump relay either way, but the signal for the lift pump goes from 12V to around 8ishV if the injection relay is installed. My first thought is a short or ground issue somewhere in the wiring but I'm starting to wonder if the dead VP44 might be causing this, or possibly a ECM issue.
Anybody else experienced this or have any thoughts?
