2001 24v cummins. Extended cab short bed SLT Laramie 172k miles, stock except level and tires
I have a 24v Cummins with 174k miles. And about 3 months my truck had a weird loss of power and check engine light came on. The 2 codes where both APP sensor or TP sensor. I tried replacing it with a. Cheap one and didn’t work so I thought I would have to buy the entire throttle body. Well sense this has happened my fuel pressure has gone from a constant to moving wonky. Where it has slowly been dropping. Where at idle it would sit at 7 at the lowest and when I hit the gas it would follow my rpm’s and go to 15 - 16. I thought it was maybe the gauge messed up or the TP sensor screwing with it. Or when I brought it to the mechanic maybe he put the sensor reader on wrong spot and so reading not consistent. Well I was driving home the other night. And it dropped to 4 fuel pressure, and when I hit my throttle it didn’t go up and the truck died. When I cycle my key it reads no fuel pressure. I have to hold my foot on gas and hold key, stop do it again and sometimes it will build pressure and start. My question is this a vp-44 injection pump problem or maybe a fuel pump problem or even just the fuel filter. ???? The codes it reads are not vp-44 related either.
