1 - 3 of 3 Posts
Any of you had a problem with vibration while traveling on highway and when it's coming to a stop. I have 05 with 6speed trans. Already replaced center support bearing and eliminate the problem partially. Any suggestion??? Possible drive shaft is out of balance? Dealer was unable to pinpoint the problem.
Did you get this vibration fixed? I don't have the front end shake at speed, just coming to a stop. Curious if you have a 5" lift or what?
1 - 3 of 3 Posts
