Off topic I just order a Bosch 0281006325 Fuel Rail Pressure Sensor. Yes the right part number for 2005 5.9If you are not turning over 3200-3400 rpm or over 45PSI you should be fine. Valve float is bad for valves and seats. Springs that are too heavy contribute to added wear and parasitic losses.
