hey yall need help im thinkin bout gettin some mods and thought that adding aftermarket valvesprings would be a good start but really what are the benefits of larger valvesprings not stock aftermarkets
:confused013:
CF Administration
there so you dont float a valve, real good investment if running higher rpms
thanks yall oh by the way are they hard to put in or are they farely a straight forward deal thanks hey evan whats up this is Ky i hav the smae rig as u what injectors do u run man
CF Administration
if you have the right tools its pretty easy, just make sure your tdc on the piston for the valves you are working on so if the valve is dropped you dont have to pull the head.
ya thanks man
