I am needing to know if i can run the stock valve springs with a s300/htb3 twins setup i need to know if the boost will open the valves or am i just worrying too much
I have mine wastegated at around 65, its hard to tell exactly cause when they hit on the street you are moving so fast you gotta pay attention to the road.RyeThomas how much boost do you see with your set up?? jw
In regards to valve springs I would use the 110 lb springs for daily driving with performance weekends.... IF it's a trailer queen 140 lb springsSo what does it take to run upwards of 90 lbs of boost?
