Look at the tech section for a lot of good articles.
These threads are organized by topic. Keep searching I know more useful threads exist.
This covers mostly non-powertrain areas.
A few powertrain threads are included.
Some things may be wrong for the 24 valve trucks. This was put together for the 12 valve engines.
Besides some minor engine changes the 1994-2002 dodge ram diesels are essentially the same machine.
A new beginning for dodge. The history of cummins diesels in dodge trucks.
Dodge Ram - Wikipedia, the free encyclopedia
Fritz's Dodge Ram Tech
Cummins Diesel Buyers Guide
Dodge Ram Diesel Engine Evolution
Cummins Diesel Motor - Diesel Power Magazine
http://dodgeram.org/tech/dsl/Facts/diesel_sales.htm Dodge diesel truck sales by year
Accessory switch installation ideas.
http://www.cumminsforum.com/forum/94-98-non-powertrain/621217-i-found-fuse-tap-installs-where-your-present-fuse-has-anyone-used-these.html
http://www.cumminsforum.com/forum/94-98-non-powertrain/169626-custom-items-youve-built.html#post1816571
http://www.cumminsforum.com/forum/94-98-non-powertrain/336265-where-did-you-put-your-extra-switches.html
http://www.cumminsforum.com/forum/94-98-non-powertrain/104357-aux-switch-installs.html
http://www.cumminsforum.com/forum/98-5-02-non-powertrain/1471986-interior-switch-pannel.html
Air compressor installation
http://www.cumminsforum.com/forum/98-5-02-non-powertrain/1502386-onboard-air-compressor-powered-cummins.html
http://www.cumminsforum.com/forum/94-98-non-powertrain/1467890-engine-driven-air-compressor.html
http://www.jedi.com/obiwan/jeep/yorkair.html
Air conditioning
http://dodgeram.org/tech/repair/HVAC/Defrost_AC.htm (Disable automatic AC when defrosting.)
http://www.cumminsforum.com/forum/94-98-non-powertrain/1321241-c-condensate-drain-mod.html
Air filter information
(Remove the space to see more)
http://www.dieselbo mbers.com/chevrolet-gmc-diesel-tech-articles/16611-duramax-air-filter-testing.html
Automatic door locks
http://www.cumminsforum.com/forum/94-98-non-powertrain/483115-how-turn-off-auto-door-locks.html
Axles.
Differential Carrier Breaks | West Coast Differentials
http://www.cumminsforum.com/forum/98-5-02-powertrain/350031-dana-80-restack-2-a.html
http://www.pirate4x4.com/forum/dodge/874442-dodge-ram-2500-4x4-dana-60-hub-removal-converison-ford-knuckles.html (4x4 front axle upgrade)
http://www.billavista.com/tech/Articles/Dana_60_Front_Axle_Bible/index.html (Dana 60 differences.)
Ball joint removal
http://www.cumminsforum.com/forum/94-98-non-powertrain/197975-ball-joint-install.html
Battery and battery terminals.
http://www.cumminsforum.com/forum/94-98-non-powertrain/917737-battery-reviews.html?highlight=
http://www.cumminsforum.com/forum/98-5-02-non-powertrain/582062-got-battery-terminals-done.html
http://www.cumminsforum.com/forum/94-98-non-powertrain/551201-battery-box-button.html
Blow Off Valve
http://www.cumminsforum.com/forum/98-5-02-performance-parts-discussion/1432953-home-brew-bov.html
Body repair and information.
http://www.cumminsforum.com/forum/auto-body/527845-squeaky-cab.html
http://dodgeram.info/tsb/1995/23-52-95a.htm (Creaking noise or exterior noise from back of cab)
http://www.cumminsforum.com/forum/auto-body/420074-well-didnt-work.html#post4428922 (Welding can badly warp metal.)
http://www.cumminsforum.com/forum/94-98-non-powertrain/1131418-bed-bolt-size.html
. Dash
This is from the tech section. Many other good articles are there.
http://www.cumminsforum.com/forum/94-98-chassis/285351-94-98-5-dash-replacement.html
http://www.cumminsforum.com/forum/94-98-non-powertrain/1420074-dashboard-extra-support-w-dynamat.html (This may help prevent dash cracking.)
http://www.cumminsforum.com/forum/94-98-chassis/273830-removing-dashboard-replacing-evaporator-1995-2500-a.html
http://www.cumminsforum.com/forum/94-98-non-powertrain/543658-trailer-brake-relocation-avoid-hitting-my-knee.html
http://www.cumminsforum.com/forum/94-98-non-powertrain/592750-weird-water-noise-cab.html
http://www.cumminsforum.com/forum/94-98-non-powertrain/435560-water-trickling-sound-dash.html
http://www.cumminsforum.com/forum/94-98-non-powertrain/767369-fluid-sound-behind-dash-weak-heater-fan.html
. Doors
http://www.cumminsforum.com/forum/94-98-non-powertrain/576503-draft-coming-through-door-seals.html
http://www.cumminsforum.com/forum/94-98-non-powertrain/559001-passenger-door-metal-door-latch.html
http://www.cumminsforum.com/forum/94-98-non-powertrain/951754-taking-off-door-panel.html
http://www.cumminsforum.com/forum/94-98-non-powertrain/550545-beltline-moulding-replacement.html
http://www.cumminsforum.com/forum/94-98-non-powertrain/418189-door-hinge-rebuild.html
http://www.cumminsforum.com/forum/98-5-02-non-powertrain/1618506-black-strip-between-my-door-windows.html
http://www.cumminsforum.com/forum/94-98-non-powertrain/253225-sagging-door.html
http://www.cumminsforum.com/forum/auto-body/645073-driver-side-suicide-door-stuck.html
. Dually information.
http://www.cumminsforum.com/forum/94-98-non-powertrain/400230-my-dually-srw-conversion-refurb.html
http://www.cumminsforum.com/forum/94-98-non-powertrain/353349-dually-box-dually-flares-removed.html
http://www.cumminsforum.com/forum/94-98-non-powertrain/512966-drw-vs-srw-rear-bed-any-difference-beside-outside-fender.html
. Frame
http://www.cumminsforum.com/forum/94-98-non-powertrain/260059-extending-frame-wheelbase-frame-size.html
. Hood release
http://www.cumminsforum.com/forum/94-98-non-powertrain/569647-hood-cable-popped-off-cant-open-hood.html
. Interior
http://www.cumminsforum.com/forum/94-98-chassis/1200921-how-fix-floppy-sun-visors.html?highlight=
http://www.cumminsforum.com/forum/94-98-non-powertrain/603087-rear-cab-interior-panel-removal.html
http://www.cumminsforum.com/forum/94-98-non-powertrain/573937-how-adjust-latch-center-console.html
http://www.cumminsforum.com/forum/94-98-non-powertrain/366065-center-arm-rest-compartment.html
http://www.cumminsforum.com/forum/auto-body/476667-painting-panels-questions.html#post4910699
http://www.cumminsforum.com/forum/98-5-02-non-powertrain/517879-2002-underseat-storage.html
http://www.cumminsforum.com/forum/94-98-non-powertrain/1513394-storage-options.html
http://www.cumminsforum.com/forum/94-98-non-powertrain/162244-what-your-most-common-interior-parts-failures-i-e-horn-buttons-seat-fabric.html
http://www.cumminsforum.com/forum/94-98-non-powertrain/525109-entry-handle-repair.html
http://www.cumminsforum.com/forum/94-98-non-powertrain/383043-2nd-gen-climate-control-knob-fix.html
http://www.cumminsforum.com/forum/94-98-non-powertrain/392495-cab-filter.html (How to get more air blowing through your ducts.)
http://www.cumminsforum.com/forum/94-98-non-powertrain/596398-where-cab-leaks.html
http://www.cumminsforum.com/forum/94-98-non-powertrain/605313-96-water-leak.html
. Paint and exterior
http://www.automotivetouchup.com/paint-code.htm
http://www.cumminsforum.com/forum/auto-body/1520178-debadged-some-paint.html
http://www.cumminsforum.com/forum/89-93-non-powertrain/1628018-side-moulding.html
http://www.cumminsforum.com/forum/general-tech-articles/110679-mirrors-color-matching.html
http://www.cumminsforum.com/forum/auto-body/600094-screwed-up-single-stage-paint-help.html
http://www.cumminsforum.com/forum/auto-body/444440-how-much-paint-buy.html
http://www.cumminsforum.com/forum/94-98-non-powertrain/541206-flaking-paint-options.html
http://www.cumminsforum.com/forum/94-98-non-powertrain/486098-project-96-painting-ideas.html
http://www.cumminsforum.com/forum/94-98-non-powertrain/400435-anyone-paint-their-engine-vanity-cover.html
http://www.cumminsforum.com/forum/detailing/379905-how-get-spray-paint-off-chrome-stack.html (Remove paint with a razor blade.)
http://www.cumminsforum.com/forum/auto-body/830049-cheap-diy-paint-job.html#post8936849
http://www.cumminsforum.com/forum/auto-body/1054858-removing-stickers-door.html
http://www.cumminsforum.com/forum/94-98-non-powertrain/548919-welding-plastic-bumper-covers.html
http://www.cumminsforum.com/forum/94-98-non-powertrain/407380-removing-emblems.html
http://www.cumminsforum.com/forum/94-98-non-powertrain/296053-how-do-you-get-plastic-off-tail-gate.html
. Rust
http://www.cumminsforum.com/forum/94-98-non-powertrain/961266-cab-mount-fender-repair.html#post11543282 (Make your own.)
http://www.cumminsforum.com/forum/94-98-non-powertrain/176645-rust-protection.html
http://www.cumminsforum.com/forum/94-98-non-powertrain/867729-lets-talk-about-rust.html
http://www.cumminsforum.com/forum/94-98-non-powertrain/574290-broken-fuel-tank-straps.html
http://www.cumminsforum.com/forum/auto-body/446446-fixing-rust.html#post4599342
http://www.cumminsforum.com/forum/auto-body/494293-rust-cab-under-carpets-what-now.html
http://www.cumminsforum.com/forum/auto-body/583540-help-me-cure-my-surface-rust.html
http://www.cumminsforum.com/forum/auto-body/1206265-rocker-panels-cab-corners.html
http://www.cumminsforum.com/forum/94-98-non-powertrain/573930-road-salt-chemicals.html
http://www.cumminsforum.com/forum/94-98-non-powertrain/603101-rust-under-carpet-where-go-here.html
http://www.cumminsforum.com/forum/94-98-non-powertrain/565485-rocker-panels.html
http://www.cumminsforum.com/forum/94-98-non-powertrain/613488-dodge-rust-repair.html
. Cab swap and time to swap over.
http://www.cumminsforum.com/forum/auto-body/358081-cab-removal.html#post4709820
http://www.cumminsforum.com/forum/auto-body/1133154-cab-salvageable.html
http://www.cumminsforum.com/forum/94-98-non-powertrain/548751-cab-swap.html
http://www.cumminsforum.com/forum/94-98-non-powertrain/599412-99-cab-96-a.html#post6522123
http://www.cumminsforum.com/forum/98-5-02-non-powertrain/1124922-question.html#post12561266
http://www.cumminsforum.com/forum/94-98-non-powertrain/1138074-cab-swap-average-cost.html#post12732506
. Windshield wipers.
http://www.cumminsforum.com/forum/89-93-non-powertrain/1676593-passenger-wiper-died.html
M101 military trailer used as a flat bed.
http://www.cumminsforum.com/forum/94-98-performance-parts-discussion/405776-od-green-tow-monster-project-begins-4.html#post4314093
When performing body work keep safety in mind. Use respirators and other safety equipment. You do not want this or worse to happen to you.
How Do I Get Herculiner Off of My Hootus?!
Boost tester
http://www.cumminsforum.com/forum/cummins-conversions-shop-talk-tools-fabrication/2610-boost-leaks.html
http://www.cumminsforum.com/forum/94-98-performance-parts-discussion/124818-boost-issue-fluctuation.html
http://www.cumminsforum.com/forum/94-98-powertrain/450878-wastegate-problems.html#post4653731
http://www.cumminsforum.com/forum/98-5-02-powertrain/623182-diy-boost-leak-tester-how.html
Brakes.
http://dodgeram.org/tech/repair/Brakes/beeding.htm
. Exhaust brake.
http://www.cumminsforum.com/forum/94-98-non-powertrain/198508-exhaust-brake-sticking.html
Unique exhaust brake idea.
http://www.cumminsforum.com/forum/94-98-non-powertrain/104357-aux-switch-installs-2.html#post1091626
http://www.cumminsforum.com/forum/3rd-gen-powertrain/498622-my-homemade-exhaust-brake.html
http://www.cumminsforum.com/forum/94-98-non-powertrain/1368001-exhaust-brake-switch.html
Instructions for bedding in your brakes
. How to fix a broken parking brake pedal assembly.
Parking Brake Fix!
http://www.cumminsforum.com/forum/94-98-non-powertrain/475550-strange-emergency-brake-repair.html
. This tech article shows the best upgrade for our rear drum brakes.
http://www.cumminsforum.com/forum/94-98-chassis/140093-37337-1-ton-wheel-cylinder-install-pics.html
http://www.cumminsforum.com/forum/94-98-non-powertrain/957162-just-did-chevy-wheel-cylinder-conversion.html
http://www.cumminsforum.com/forum/94-98-non-powertrain/579339-2wd-disk-rotor-upgrade.html
http://www.cumminsforum.com/forum/98-5-02-non-powertrain/611925-idea-mounting-3rd-gen-front-brakes-99-earlier-2wds.html
http://www.cumminsforum.com/forum/94-98-non-powertrain/1385353-hydroboost-brake-booster-conversion.html
http://www.cumminsforum.com/forum/89-93-non-powertrain/1609938-hydroboost-conversion.html (1st gen.)
. This thread shows brake pad comparisons.
Need New Front Brake Pads - Dodge Diesel - Diesel Truck Resource Forums
. How to get the self adjusters to work.
http://www.cumminsforum.com/forum/general-tech-articles/434-brake-revitalization.html#post23667
. Stuck on brake drums? Here is the solution for getting them off easily.
http://www.cumminsforum.com/forum/94-98-non-powertrain/182197-2nd-gen-dually-brake-shoe-replacment.html
http://www.cumminsforum.com/forum/94-98-non-powertrain/451560-tips-rear-drum-removal.html
. Warped rotors? read these.
http://www.cumminsforum.com/forum/94-98-non-powertrain/189173-shaking-while-braking.html
http://www.cumminsforum.com/forum/94-98-non-powertrain/196972-warped-rotors.html
http://www.cumminsforum.com/forum/94-98-non-powertrain/538078-my-second-set-rotors-12-months-warped.html
http://www.cumminsforum.com/forum/94-98-non-powertrain/592524-grabby-front-brakes.html
Bumper
http://www.cumminsforum.com/forum/94-98-non-powertrain/1497842-front-bumper-adjustable-1997-dodge-ram.html
http://www.cumminsforum.com/forum/94-98-non-powertrain/472878-3rd-gen-rear-bumper-2nd-gen.html
http://www.cumminsforum.com/forum/auto-body/240598-3rd-gen-bumper-2nd-gen.html (Front bumper)
http://www.cumminsforum.com/forum/94-98-non-powertrain/520595-4th-gen-bumper-2nd-gen.html
http://www.cumminsforum.com/forum/94-98-non-powertrain/535649-4th-gen-bumper-2nd-gen-truck-pictures.html
http://www.cumminsforum.com/forum/94-98-non-powertrain/449820-lets-see-your-custom-built-front-bumpers.html
http://www.cumminsforum.com/forum/show-time/192366-94-02-custom-bumpers.html
. This shows how some members built their own custom bumper.
http://www.cumminsforum.com/forum/94-98-non-powertrain/515038-front-bumper-build-finally.html
http://www.cumminsforum.com/forum/98-5-02-non-powertrain/180140-homemade-bumper-total-cost-150-a.html
http://www.cumminsforum.com/forum/98-5-02-non-powertrain/206186-my-bumper.html
Buyers guides.
Turbo Diesel Buyers Guide
10 Best Used Diesel Trucks (and cars) - Diesel Power Magazine All Pages
http://www.cumminsforum.com/forum/94-98-non-powertrain/516826-1-ton-pros-cons.html
http://www.cumminsforum.com/forum/94-98-powertrain/395853-i-need-help-choosing-year-options-ton-truck-heavy-hauling.html
http://www.cumminsforum.com/forum/94-98-non-powertrain/602140-salvage-title-question.html
This covers most of the differences between a VE, P7100, VP44 and early CR trucks.
http://www.cumminsforum.com/forum/94-98-powertrain/456254-trying-pick-best-model-cummins-dd.html#post4699697
http://www.cumminsforum.com/forum/94-98-powertrain/582484-12-valve-injector-injection-pump-life-compared-vp44-common-rail.html
From this sites tech section.
http://www.cumminsforum.com/forum/94-98-tech-articles/434296-looking-buy-12-valve-recently-bought-one-read.html
Cab Lights
http://www.cumminsforum.com/forum/94-98-non-powertrain/909298-cab-light-fasteners-need-part-number-cant-find-them.html
CB Radio
http://www.cumminsforum.com/forum/94-98-non-powertrain/505533-cb-still-worth-installing-now-so-many-people-use-cellphones.html
http://www.cumminsforum.com/forum/98-5-02-non-powertrain/325754-where-did-you-mount-your-cb-pics.html
http://www.cumminsforum.com/forum/98-5-02-non-powertrain/440992-any-slick-cb-mounting-options.html
http://www.cumminsforum.com/forum/94-98-non-powertrain/633257-installing-cb-below-radio-pics.html
http://www.cumminsforum.com/forum/94-98-non-powertrain/273149-cb-install-3.html
Charging system.
http://www.cumminsforum.com/forum/94-98-non-powertrain/556805-how-about-installing-class-8-truck-alternator-your-truck-has-been-done.html
Cold weather ideas.
http://www.cumminsforum.com/forum/94-98-non-powertrain/354977-simple-winter-front.html
http://www.cumminsforum.com/forum/94-98-non-powertrain/761041-anyone-using-winter-front-how-do-you-like.html
http://www.cumminsforum.com/forum/94-98-non-powertrain/222295-prepping-truck-cold.html
Computer codes.
http://www.obd-codes.com/trouble_codes (Shows all possible codes.)
http://www.troublecodes.net/OBD2/ (Explains what each digit means.)
http://dodgeram.org/tech/dsl/troubleshooting/94_DTC_codes.htm (1994 dodge computer codes)
Cruise Control
Solve surging cruise control.
http://www.dieseltruckresource.com/forums/24-valve-engine-drivetrain-89/surging-cruise-81812/#post795184
http://www.cumminsforum.com/forum/94-98-non-powertrain/1099426-cruse-control-diagnosis.html
http://www.cumminsforum.com/forum/94-98-non-powertrain/606422-cruise-buttons.html
http://www.cumminsforum.com/forum/94-98-non-powertrain/1127226-cleaning-cruise-control-buttons.html
http://www.cumminsforum.com/forum/94-98-non-powertrain/589391-guide-diagnosing-cruise-control-problems-96-97-trucks.html
Cup holders and the the factory cup holder space modifications.
http://www.cumminsforum.com/forum/94-98-non-powertrain/582601-dash-repair-cupholder.html
http://www.cumminsforum.com/forum/94-98-non-powertrain/484799-what-do-cupholder-cavity.html
http://www.cumminsforum.com/forum/94-98-non-powertrain/496438-anyone-use-98-console.html
http://www.cumminsforum.com/forum/94-98-non-powertrain/543997-shifter-cup-holders.html#post5638579
http://www.cumminsforum.com/forum/94-98-non-powertrain/464799-finally-cup-holder-my-97-does-what-should-hold.html
http://www.cumminsforum.com/forum/94-98-non-powertrain/447534-97-cup-holder-replacement.html
http://www.cumminsforum.com/forum/94-98-non-powertrain/425040-cupholder-floor-replacement.html
http://www.cumminsforum.com/forum/94-98-non-powertrain/1459970-genos-cup-holders.html
http://www.cumminsforum.com/forum/94-98-non-powertrain/109446-cup-holder-am-i-only-1-a.html
http://www.cumminsforum.com/forum/98-5-02-non-powertrain/1168650-writeup-4th-gen-center-console-swap.html
http://www.cumminsforum.com/forum/94-98-non-powertrain/612051-genos-center-console-cupholers-stick-shift.html
http://www.genosgarage.com/DODGE-RAM-CENTER-CONSOLE-CUP-HOLDER-94-97/productinfo/CUP-HOLDER-9497/
http://www.genosgarage.com/DODGE-RAM-CENTER-CONSOLE-CUP-HOLDER-98-02-2500_3500/productinfo/CUP-HOLDER-9802/
http://www.cumminsforum.com/forum/94-98-non-powertrain/336265-where-did-you-put-your-extra-switches-3.html
http://www.cumminsforum.com/forum/94-98-non-powertrain/470387-cup-holder-solution-extended-cab.html
Double din radio installation.
1994-1997
http://www.cumminsforum.com/forum/accessories-installations/113640-my-double-din-install-2nd-gen-truck-2.html
http://www.cumminsforum.com/forum/94-98-non-powertrain/871642-double-din-gauges.html
http://www.cumminsforum.com/forum/94-98-non-powertrain/566136-my-double-din-conversion.html
http://www.cumminsforum.com/forum/electrical-wiring/407281-kenwood-dnx6980-double-din-dvd-nav-installed-96-pics.html
http://www.cumminsforum.com/forum/94-98-non-powertrain/423653-dual-din-dash-build.html
http://www.cumminsforum.com/forum/94-98-non-powertrain/623960-double-din-conversion-ideas-96-a.html
http://www.cumminsforum.com/forum/98-5-02-non-powertrain/1329737-diy-custom-gauges-instrument-bezel-double-din.html
http://www.cumminsforum.com/forum/94-98-non-powertrain/1534258-double-din-head-unit-pics.html
If you have a 1998 - 2002 truck these are for you.
http://www.cumminsforum.com/forum/94-98-non-powertrain/1298497-double-dinn-switches.html
http://www.cumminsforum.com/forum/98-5-02-non-powertrain/1238921-soundproofing-truck-double-din-stereo-project.html
http://www.cumminsforum.com/forum/98-5-02-non-powertrain/523678-double-din-radio-bezel-8.html I started this on page 8 for a reason. Pages 8-13 are useful. This shows fabrication.
Reactions: runit02
Discussion Starter #2 (Edited)
Engine. This is based on 12 valve. What remains may or may not apply to the VP44 in the 1998.5-2002 rams.
http://www.cumminsforum.com/forum/94-98-powertrain/1649154-12-valve-engine-overhaul-manual-free.html
http://www.cumminsforum.com/forum/94-98-performance-parts-discussion/445455-hamilton-camshaft-test.html
http://www.cumminsforum.com/forum/94-98-performance-parts-discussion/1388673-how-much-difference-does-cam-make.html
http://www.cumminsforum.com/forum/94-98-engine/223095-what-kdp.html
Ram Diesel KDP retainer
The dowel pin is not the only potential engine killer. Read this.
http://www.cumminsforum.com/forum/94-98-powertrain/591417-broke-cam.html
Inspect your Harmonic Damper from time to time.
TDR 73: It's Time to Check Your Cummins Harmonic Damper
http://www.cumminsforum.com/forum/89-93-powertrain/1681593-injector-removal-tool.html (How to make your own.)
http://www.cumminsforum.com/forum/general-diesel-discussion/127696-modify-stock-airbox.html
http://www.cumminsforum.com/forum/94-98-performance-parts-discussion/347178-home-made-water-methanol-injection-system.html
12V TPS Wiring Diagram
http://www.cumminsforum.com/forum/94-98-non-powertrain/395314-tick-behind-cab.html
http://www.cumminsforum.com/forum/94-98-powertrain/1643898-taking-off-exhuast-manifold.html
http://www.cumminsforum.com/forum/94-98-non-powertrain/1630002-valve-cover-vents.html (for excessive blowby)
http://www.cumminsforum.com/forum/98-5-02-powertrain/111278-mechanical-high-idle-bomb-completed.html
http://www.cumminsforum.com/forum/94-98-non-powertrain/298941-budget-blow-bottle.html
http://www.cumminsforum.com/forum/94-98-non-powertrain/550708-afc-intake-plastic-hose.html
Engine oil tests.
You can send your oil in for oil analysis.
Your local heavy truck or tractor dealer may have a reasonably priced oil testing service.
Engine Oil filter.
http://www.genosgarage.com/GenosGarageTechArticles/TDR71_LubeOilFiltration.pdf
Then there is this option.
http://www.cumminsforum.com/forum/94-98-powertrain/563139-lubricheck.html
http://www.cumminsforum.com/forum/94-98-non-powertrain/795778-lubricheck-oil-analysis-product.html
This is where you find the product.
lubricheck The digital 'blood tester' for your car
Exhaust.
http://www.cumminsforum.com/forum/94-98-performance-parts-discussion/704849-aftermarket-exhaust-manifold-did-you-get-how-has-worked-out-you.html
http://www.cumminsforum.com/forum/94-98-non-powertrain/1107986-opinions-cat-back-vs-turbo-back-exhaust.html
http://www.cumminsforum.com/forum/94-98-non-powertrain/570845-can-4-exhaust-actually-increase-mpg.html
This looks like a great product if your exhaust is to loud.
http://www.cumminsforum.com/forum/ftediesel-com/100155-new-style-resonators-mufflers-available.html
FTE resonator review.
http://www.cumminsforum.com/forum/98-5-02-powertrain/623033-wrapping-exhaust-topic.html
http://www.cumminsforum.com/forum/94-98-non-powertrain/509045-how-clean-your-catalytic-converter.html
If you install stacks this protects things in your bed while looking good.
http://www.cumminsforum.com/forum/accessories-installations/128701-diy-stack-heat-shield.html
http://www.cumminsforum.com/forum/94-98-non-powertrain/575580-finally-finished-stack-throught-tool-box.html
Fog lights.
Fog light mod - DodgeForum.com
DIY- Keeping Fog Lights On With High Beams - DodgeForum.com
http://www.cumminsforum.com/forum/94-98-non-powertrain/358766-putting-fog-lights-non-fog-lit-truck.html
http://www.cumminsforum.com/forum/94-98-non-powertrain/875618-adding-factory-fog-lights.html
http://www.cumminsforum.com/forum/94-98-non-powertrain/1126010-not-usual-fog-light-question.html
http://www.cumminsforum.com/forum/94-98-non-powertrain/616763-fog-light-switch.html#post6493255 (mentions wire colors)
http://www.cumminsforum.com/forum/94-98-non-powertrain/466388-factory-fog-light-switch.html
http://www.cumminsforum.com/forum/94-98-non-powertrain/561642-fog-lights.html (shows wiring diagram)
http://www.cumminsforum.com/forum/94-98-non-powertrain/175116-fog-lights-brights.html
http://www.cumminsforum.com/forum/94-98-non-powertrain/1106490-factory-fog-lights.html
Fuel capacity.
http://www.cumminsforum.com/forum/94-98-non-powertrain/577069-fuel-capacity-my-truck.html
Fuel filter
Fuel Pre-Filter cleaning
Fuel Pre-Filter Cleaning on Ram/Cummins
How to change a fuel filter
Fuel Filter Change 1994-1996 (1994-1995)
Ram 97+ Diesel Fuel Filter Change (1997-1999)
Fuel pressure.
The VP44 is vulnerable to low fuel pressure. Install a fuel pressure gauge and look at it now and again.
Fuel prices.
GasBuddy.com - Find Low Gas Prices in the USA and Canada
Fuel sending unit. (May or may not apply to the 24 valves)
http://www.cumminsforum.com/forum/94-98-non-powertrain/195506-fuel-sending-unit-how-many-ohms.html
http://www.cumminsforum.com/forum/94-98-non-powertrain/494115-sending-unit-float-assembly.html
http://www.cumminsforum.com/forum/94-98-non-powertrain/196214-tank-sending-unit-replacement.html
http://www.cumminsforum.com/forum/98-5-02-non-powertrain/326807-sending-unit-fuel-lines-stuck-help.html
Repair not replacement. This does not work for all trucks.
http://www.cumminsforum.com/forum/98-5-02-non-powertrain/387473-fuel-sending-unit-repair-under-1-a.html
CJ Johansson's fuel sender repair
Dodge ram Fuel Tank Sender Repair
Gauge installation ideas for pyrometer, boost, and other aftermarket gauges.
http://www.cumminsforum.com/forum/94-98-non-powertrain/251730-installed-pyro-boost-gages.html (Proper locations for the sending units are shown.)
http://www.cumminsforum.com/forum/94-98-powertrain/292874-where-put-trans-temp-sender.html (Look at more than the first page.)
http://www.cumminsforum.com/forum/94-98-non-powertrain/225280-gauges-installed-now.html (Good numbers to look at are inside.)
http://www.cumminsforum.com/forum/94-98-non-powertrain/560437-gauge-install-time.html
http://www.cumminsforum.com/forum/94-98-non-powertrain/569316-tips-guage-install.html
http://www.cumminsforum.com/forum/94-98-non-powertrain/195567-please-help-trans-temp-install-w-pics.html
Several links are inside.
http://www.cumminsforum.com/forum/94-98-powertrain/590411-multi-display-gauge-question.html#post6164533
http://www.cumminsforum.com/forum/94-98-non-powertrain/553788-gauges-installed-pics.html
http://www.cumminsforum.com/forum/94-98-non-powertrain/1468754-dash-gauge-mount-options.html
http://www.cumminsforum.com/forum/94-98-non-powertrain/623948-making-more-room-gauges.html
http://www.cumminsforum.com/forum/94-98-performance-parts-discussion/520045-cupholder-gauges.html
http://www.cumminsforum.com/forum/94-98-non-powertrain/695769-overhead-gauge-pod.html
http://www.cumminsforum.com/forum/94-98-non-powertrain/565686-fuel-pressure-gauge-location.html
This shows 3 gauges in a 1996 bezel.
http://www.cumminsforum.com/forum/98-5-02-non-powertrain/514896-4th-gauge-mounting.html#post5316529
This is a very clean 3 gauge install in a 1st gen. They could have been factory.
http://www.cumminsforum.com/forum/89-93-non-powertrain/1459266-interior-project-4.html#post18330434
This shows how to design and make your own 3 gauge pillar.
http://www.cumminsforum.com/forum/89-93-non-powertrain/1647882-3-gauge-1st-gen-pillar-pod.html
Stock dash gauges not working possible fix.
http://www.cumminsforum.com/forum/94-98-non-powertrain/357966-instrument-cluster.html
Grid heater.
How to troubleshoot.
Ram Diesel Manifold Heater Problems
This can save you some money.
http://www.cumminsforum.com/forum/94-98-engine/341499-grid-heater-relay-replacement.html
Grilles.
http://www.cumminsforum.com/forum/accessories-installations/501128-options-2nd-gen-grills.html
http://www.cumminsforum.com/forum/94-98-non-powertrain/569896-grill-led-backlight.html#post5938566
http://www.cumminsforum.com/forum/94-98-non-powertrain/532579-replacement-1994-2002-grille-options-under-125-shipped.html
http://www.cumminsforum.com/forum/94-98-non-powertrain/470105-custom-grilles-what-do-you-have.html
http://www.cumminsforum.com/forum/auto-body/267767-how-dechrome-grill.html
Headlights.
(Not headlights, but worth considering.)
http://www.cumminsforum.com/forum/94-98-non-powertrain/695353-looking-do-leds.html
Water in the headlight housings caused blown bulbs.
http://www.cumminsforum.com/forum/94-98-non-powertrain/466700-not-your-typical-headlight-repair.html
Recall 819 (Read this.)
http://www.cumminsforum.com/forum/94-98-non-powertrain/334765-recall-819-melting-headlight-switch-15-00-fix.html
http://www.cumminsforum.com/forum/94-98-non-powertrain/607008-headlights-not-working-recall-819-a.html
http://www.cumminsforum.com/forum/94-98-non-powertrain/222491-how-remove-headlights.html
If you replace your headlights adjust them. This shows how.
Daniel Stern Lighting Consultancy and Supply
As a FYI some of the aftermarket options have reviews saying their light output is not good.
Look for reviews before buying a replacement pair.
http://www.cumminsforum.com/forum/98-5-02-non-powertrain/1376361-headlight-ideas.html#post15444497
Polishing your yellowed headlights is often a good option.
http://www.cumminsforum.com/forum/94-98-performance-parts-discussion/1198761-whats-best-head-lights-95-dodge.html#post13433241
http://www.cumminsforum.com/forum/94-98-non-powertrain/262765-confused-about-headlight-options.html
http://www.cumminsforum.com/forum/94-98-non-powertrain/119517-mod-all-headlights-same-time.html
The pieces removed here are used to align your headlights.
http://www.cumminsforum.com/forum/98-5-02-non-powertrain/473685-polising-your-headlights-removing-alignment-nodes.html
http://www.cumminsforum.com/forum/94-98-non-powertrain/1354849-headlight-tits-removed.html
http://www.cumminsforum.com/forum/94-98-non-powertrain/432957-hid-install.html
http://www.cumminsforum.com/forum/94-98-non-powertrain/353459-headlight-wiring-harness-only-headlight-mod.html
http://www.cumminsforum.com/forum/98-5-02-non-powertrain/1055850-led-headlights-yes-headlights.html
. Sport headlights (The 1998-2002 should not need new holes for the second bulb)
Sport Headlight Conversion (lots of photos)
Dodge Ram Sport Headlight Conversion
http://www.cumminsforum.com/forum/94-98-non-powertrain/338141-sport-headlight-conversion-harness-need-pics.html
http://www.cumminsforum.com/forum/94-98-non-powertrain/85407-sport-headlight-conversion.html
http://www.cumminsforum.com/forum/94-98-non-powertrain/329941-just-bought-sport-headlights-accident-how-upgrade.html
http://www.cumminsforum.com/forum/98-5-02-non-powertrain/806730-headlight-harness-idea.html
http://www.cumminsforum.com/forum/98-5-02-non-powertrain/561464-2nd-gen-dodge-ram-hid-projector-retrofit-diy-tutorial-pics.html
Wiring modifications for brighter lights.
http://www.cumminsforum.com/forum/94-98-non-powertrain/592453-need-modest-driving-light-suggestions-while-i-plan-headlight-fix.html
Another Headlight Mod Question - Dodge Diesel - Diesel Truck Resource Forums
http://www.cumminsforum.com/forum/94-98-non-powertrain/995082-headlight-upgrade-time.html
Ram Headlight & Fog Light Mods: Enable Low Beams with High Beam Enable Fog light with High Beam
Ram headlight switching modifications
Headliner.
If you are planning on replacing your headliner material use "DAP Weldwood Landau Top & Trim Contact Adhesive".
Nothing else compares or does what this does. It only comes in gallon cans.
https://www.fabricsupply.com/cart/product/show/5/Supplies---Tools/14/DAP-Weldwood-Landau-Top---Trim-Contact-Adhesive shows what to look for.
In some states this glue is illegal. The VOC content is to high. However, you just might be able to mail order this from a supplier who does not realize your state is off limits.
http://www.cumminsforum.com/forum/show-time/99042-my-custom-headliner.html
http://www.cumminsforum.com/forum/94-98-non-powertrain/474863-diy-headliner.html
http://www.cumminsforum.com/forum/94-98-non-powertrain/423957-headliner-issues.html
http://www.cumminsforum.com/forum/detailing/508025-headliner-cleaning.html
well my Head liners out - Dodge Diesel - Diesel Truck Resource Forums
http://www.cumminsforum.com/forum/94-98-non-powertrain/470778-headliner-question.html (A quad cab is different from a club cab.)
Heater.
The most expensive way to have a warm cab.
http://www.cumminsforum.com/forum/2010-2012-general-discussion/1364649-installed-my-webasto-coolant-heater-pics-inside.html
http://www.cumminsforum.com/forum/94-98-non-powertrain/353075-how-i-fixed-my-heat-problem-now.html
http://www.cumminsforum.com/forum/94-98-non-powertrain/1070306-heater-hose-size.html
If you heater does not change positions this may be the part you need.
HeaterTreater™
This shows the necessary part
Dodge Ram '95-'02 - '95 - '02 - Ram - Dodge
High idle idea. This is for a 1st gen truck.
http://www.cumminsforum.com/forum/89-93-non-powertrain/266045-cruise-control-servo-high-idle-write-up.html
Horn
http://www.dieseltruckresource.com/forums/2nd-gen-dodge-ram-no-drivetrain-90/97-slt-steering-horn-buttons-removable-193574/
Ignition switch.
Ignition Switch Replacement
http://www.cumminsforum.com/forum/94-98-non-powertrain/1651538-programming-key-fob-without-chrysler-tool.html
KDP
http://www.cumminsforum.com/forum/94-98-non-powertrain/607427-homemade-kdp-kit.html
Map light repair.
http://www.cumminsforum.com/forum/98-5-02-non-powertrain/360472-broken-maplighst-overhead-console-check-out.html
Miles Per Gallon.
http://www.cumminsforum.com/forum/94-98-non-powertrain/779297-stupid-question-how-drive-12v.html
http://www.cumminsforum.com/forum/94-98-powertrain/287609-whats-your-best-mpg-12v.html
http://www.cumminsforum.com/forum/94-98-powertrain/433131-why-tow-2-000-rpms-best-m-p-g-1-600-max-torque-right.html
Turbo Diesel Register Tech: It's About the (fuel) Economy Stupid!
http://www.cumminsforum.com/forum/94-98-performance-parts-discussion/507534-30-mpg-12v.html
http://www.cumminsforum.com/forum/towing-hauling/25849-enclosed-underbelly-what-difference.html
http://www.cumminsforum.com/forum/3rd-gen-powertrain/337978-better-mpgs.html#post3544429
IT'S ABOUT THE (fuel) ECONOMY STUPID! (Use the next page arrow. The page numbers are broken.)
Does going faster really save you much time or does it really cost you more fuel money?
http://www.cumminsforum.com/forum/94-98-non-powertrain/568867-cross-country-trip-tips.html#post5926518
http://www.cumminsforum.com/forum/94-98-powertrain/554767-please-post-how-changing-timing-affected-your-fuel-economy-power-levels-here.html
http://www.cumminsforum.com/forum/94-98-powertrain/497762-has-anyone-put-215-close-injectors-180-truck-seen-improved-mpg.html
http://www.cumminsforum.com/forum/94-98-performance-parts-discussion/469897-does-torque-converter-lower-stall-speed-improve-fuel-economy.html
Before you add big aggressive tread tires read this.
The Effects of Rotational Inertia on Automotive Acceleration
http://www.cumminsforum.com/forum/94-98-non-powertrain/237291-body-lift-making-poor-mpg.html
http://www.cumminsforum.com/forum/94-98-non-powertrain/430440-new-tires-mpg.html
http://www.cumminsforum.com/forum/94-98-non-powertrain/1117858-dually-owners-what-you-averaging.html
Mirrors, Towing.
This is what had to be done to get power mirrors for our trucks in the past.
http://www.cumminsforum.com/forum/98-5-02-non-powertrain/157873-factory-power-tow-mirror-swap-3rd-2nd-gen.html
Power mirrors are now available from the aftermarket in a few different styles.
http://www.cumminsforum.com/forum/94-98-non-powertrain/480019-tow-mirror-part-numbers-descriptions-your-search-your-1994-2002-truck.html
One member added a light to the outside of his tow mirrors. He also added a turn signal behind the mirror glass.
http://www.cumminsforum.com/forum/94-98-non-powertrain/1263985-tow-mirror-reworked.html
You can buy an additional spot mirror that clamps to your current mirror. This is just one example. There are also glue on spot mirrors you can use in different shapes.
Amazon.com: Side Mirror - Auxiliary Car Mirror Offers Wide Angle View: Automotive
http://www.cumminsforum.com/forum/94-98-non-powertrain/1458362-painting-plastic-tow-mirrors.html
http://www.cumminsforum.com/forum/94-98-non-powertrain/449298-2nd-gen-towing-mirrors-best.html
Overdrive switch.
If yours does not work perfectly try this repair.
http://www.cumminsforum.com/forum/98-5-02-powertrain/597489-clean-od-button.html
Power steering.
http://www.cumminsforum.com/forum/94-98-non-powertrain/1584354-spin-power-steering-filter.html
http://www.cumminsforum.com/forum/94-98-powertrain/1387641-power-steering-pump-explained.html
http://www.cumminsforum.com/forum/98-5-02-powertrain/907130-single-digit-cold-start-noise.html
http://www.cumminsforum.com/forum/98-5-02-powertrain/1399769-vacuum-pump-shaft.html#post15804905
http://www.cumminsforum.com/forum/98-5-02-non-powertrain/1214409-power-steering-brakes-acting-up.html#post13611649
http://www.cumminsforum.com/forum/94-98-powertrain/719985-oil-leak-drivers-side-tappet-cover.html#post7590473
http://www.cumminsforum.com/forum/94-98-non-powertrain/598419-power-steering-help.html
Discussion Starter #3 (Edited)
Radio.
http://www.cumminsforum.com/forum/94-98-non-powertrain/256386-looking-radio-wiring-diag-infinaty-sound.html
http://www.cumminsforum.com/forum/98-5-02-non-powertrain/179830-tweeters-gauge-pillar.html
https://autonewszone.wordpress.com/2009/03/17/car-sterio-din-explained-size-and-definition/
http://www.cumminsforum.com/forum/98-5-02-non-powertrain/12026-aftermarket-speakers.html
http://www.cumminsforum.com/forum/98-5-02-non-powertrain/451161-speaker-sizes.html
http://www.cumminsforum.com/forum/98-5-02-non-powertrain/844482-how-add-aux-input-rbr-radio.html
http://www.cumminsforum.com/forum/98-5-02-non-powertrain/1218633-club-cab-custom-subwoofer-box-build-w-pics.html
http://www.cumminsforum.com/forum/94-98-non-powertrain/419379-center-rear-seat-sub-box-crutchfield.html
http://www.cumminsforum.com/forum/94-98-non-powertrain/1459202-radio-cd-player-upgrade.html
. Alternator whine (generator whine in our trucks).
Noise Troubleshooting Guide -- Eliminate your alternator whine
Noise suppression guide
Car Audio - Alternator Noise
Seat repair and options.
http://www.cumminsforum.com/forum/94-98-non-powertrain/1611754-odd-looking-seats-my-new-truck.html (Base model seat pictures)
http://www.cumminsforum.com/forum/98-5-02-non-powertrain/887450-so-i-rebuilt-my-seats.html
http://www.cumminsforum.com/forum/94-98-non-powertrain/1408321-94-04-seat-up-grade.html
http://www.cumminsforum.com/forum/94-98-non-powertrain/1205017-those-need-better-seats-300m-bucket-seat-swap.html
http://www.cumminsforum.com/forum/98-5-02-non-powertrain/534023-ahhh-new-seats.html
http://www.cumminsforum.com/forum/94-98-non-powertrain/1420042-3rd-gen-seat-swap-custom-interior.html
http://www.cumminsforum.com/forum/94-98-non-powertrain/798522-4th-gen-seat-swap.html
How To: install 3 Gen seats in a 2 Gen - DodgeTalk
http://www.cumminsforum.com/forum/94-98-non-powertrain/452815-3rd-gen-seat-install-pics.html
http://www.cumminsforum.com/forum/94-98-non-powertrain/398516-removing-center-console.html
http://www.cumminsforum.com/forum/94-98-non-powertrain/1532674-08-chevrolet-seats-my-97-a.html
http://www.dodgetalk.com/forums/showthread.php?t=211379
http://www.cumminsforum.com/forum/94-98-non-powertrain/279106-98-02-seat-swap.html
http://www.cumminsforum.com/forum/94-98-non-powertrain/2877-back-seat-troubles.html (How to remove the back seat in a club or quad cab.)
http://www.cumminsforum.com/forum/94-98-non-powertrain/500127-racing-bucket.html
http://www.cumminsforum.com/forum/94-98-non-powertrain/609452-favorite-seat-covers.html
You can have heated seats if you buy these, or something similar.
Rostra dual element seat heater-Geno's Garage
Short bed conversion.
http://www.cumminsforum.com/forum/94-98-non-powertrain/491795-94-reg-cab-short-bed-4x4-build.html
A short bed and 4 doors. It took years before the conversion was finished.
http://www.cumminsforum.com/forum/auto-body/316599-2nd-gen-crew-cab-conversion.html
Do NOT do it this way. :doh:
http://www.cumminsforum.com/forum/94-98-powertrain/459997-regcabshortbed-6-single-stack-hood-scoop.html#post4737067
Smoother ride.
http://www.cumminsforum.com/forum/94-98-non-powertrain/1122114-need-smoother-ride.html
Installing Polyurethane Spring Tip Inserts - Dodge Diesel - Diesel Truck Resource Forums (For the 1st gen trucks.)
Sound reduction for your truck.
http://www.cumminsforum.com/forum/89-93-non-powertrain/576604-ideas-consider-when-soundproofing-your-truck.html
Here is my sound reduction attempt which was added to the thread posted above.
http://www.cumminsforum.com/forum/94-98-non-powertrain/1175737-my-sound-reduction-odyssey.html
Jim L shows a similar approach in his 1st gen truck.
This is interesting as he modifies his springs and his truck is then quieter.
http://www.cumminsforum.com/forum/89-93-non-powertrain/1091170-comfortable-1st-gen.html
This TSB may solve some drone for those with a 1994-1996 truck
NOTE: 1996 2500 CLUB CAB, 155" WB 4X4 AND HEAVY DUTY TRANSFER CASE (SALES CODE DHG)
(BUILT AFTER MAY 9,1996 (MDH 05-09-XX)) ARE ASSEMBLED WITH THE REVISED PROPELLER SHAFT
http://dodgeram.info/tsb/1996/03-03-96.htm
Here one member worked under their hood. Be careful, some foam can expand to much and seriously dent and damage your sheet metal.
http://www.cumminsforum.com/forum/94-98-non-powertrain/29570-quieting-down-racket.html
Steering.
Ram Steering Gear Adjustments
http://dodgeram.info/tsb/1997/19-10-97.htm
http://dodgeram.info/tsb/1997/19-10-97.htm (Steering Wander)
http://www.cumminsforum.com/forum/94-98-non-powertrain/1262601-how-remove-power-steering-box.html
Do not forget your control arm bushings can go bad too.
http://www.cumminsforum.com/forum/94-98-non-powertrain/258080-strange-steering-problems-input-repair.html
Sway bars.
http://www.cumminsforum.com/forum/94-98-non-powertrain/551836-slide-camper-rear-sway-bar-mia.html
TPS
http://www.dieseltruckresource.com/forums/1st-gen-ram-all-topics-93/installing-potentiometer-place-tps-142641/
POT mod along with the original TPS to modify shift points.
http://www.dieseltruckresource.com/forums/1st-gen-ram-all-topics-93/super-cool-cheap-tps-fix-dial-your-od-shift-point-42003/page8/#post3193978
http://dieseldatabase.com/12v-tps-wiring-diagram/?id=54
http://www.cumminsforum.com/forum/94-98-powertrain/1204385-10-turn-pot-od-lockup-tps-delete.html
http://dodgeram.org/tech/transmission/automatic/TPS_adjust.htm
Tires and wheels.
http://www.cumminsforum.com/forum/94-98-non-powertrain/196415-best-way-balance-wheels.html
http://www.cumminsforum.com/forum/94-98-non-powertrain/507441-self-balancing-beads.html
http://www.cumminsforum.com/forum/94-98-non-powertrain/219018-winter-traction.html
http://sipers.com/about/
http://www.sizemytires.com/calculators/compare
http://www.cumminsforum.com/forum/94-98-non-powertrain/257915-tire-size-vs-fuel-economy.html
http://www.cumminsforum.com/forum/94-98-non-powertrain/571389-3rd-gen-dually-wheel-2nd-gen.html
http://www.cumminsforum.com/forum/94-98-non-powertrain/1427250-e-load-only-6-ply.html
Tool box, tools, spare filters and parts.
http://www.cumminsforum.com/forum/94-98-non-powertrain/1365569-spares-tools-keep-hand.html
http://www.cumminsforum.com/forum/94-98-non-powertrain/207433-what-keep-box.html
http://www.cumminsforum.com/forum/94-98-non-powertrain/418203-cross-country-trip-what-do-what-bring.html
http://www.cumminsforum.com/forum/94-98-non-powertrain/1626730-buying-maintenance-supplies-where-buy.html
Towing
http://www.cumminsforum.com/forum/94-98-non-powertrain/1030842-when-should-i-turn-o-d-off.html
http://www.cumminsforum.com/forum/94-98-non-powertrain/613914-towing-question-2nd-gen-ers.html
http://www.cumminsforum.com/forum/94-98-non-powertrain/1625458-porpoising-while-towing-gooseneck.html (in this case it was throttle springs)
http://www.cumminsforum.com/forum/94-98-non-powertrain/377405-smoother-towing-options.html
http://dodgeram.info/tsb/2001/02-001-01.htm (Rear Of Vehicle Sits Too High To Allow Hook Up To A Fifth Wheel Trailer)
http://www.cumminsforum.com/forum/94-98-non-powertrain/1331073-custom-5er-install.html
Transmission, automatic.
http://www.cumminsforum.com/forum/98-5-02-powertrain/1434945-tc-stall-selection-some-good-info.html#post16200113
http://www.cumminsforum.com/forum/98-5-02-powertrain/478658-finally-how-rebuild-your-47-48re.html
http://www.cumminsforum.com/forum/98-5-02-modifications/452339-auto-tranny-upgrades-increased-hp-engines.html
http://www.cumminsforum.com/forum/94-98-drivetrain-except-engine/452157-proper-upgrade-list-transmission.html
http://www.cumminsforum.com/forum/94-98-performance-parts-discussion/623185-sfi-29-1-compared-billet-sfi-29-3-flexplate-question.html
Torque converter lock up switch. Great if used properly. Can break a transmission if used badly. Do not lug your engine.
http://www.tstproducts.com/Torque Converter Lockup Switch.pdf
http://www.cumminsforum.com/forum/94-98-powertrain/756665-torque-converter-lock-up-switch-install-problem.html
http://www.cumminsforum.com/forum/94-98-performance-parts-discussion/511206-torque-converter-lockup-swicth-does-risk-shifting-down-gear-accidentally.html
http://www.cumminsforum.com/forum/94-98-powertrain/421812-how-raise-shift-points-step-step.html
This is where the idea came from originally.
valve body pressure lever - Competition Diesel.Com - Bringing The BEST Together
http://www.cumminsforum.com/forum/94-98-performance-parts-discussion/406007-how-do-i-delay-47re-shift-points.html
Remove the space to see more about transmission test ports.
http://www.dieselbo mbers.com/12-valve-2nd-gen-dodge-cummins-94-98/97528-47re-test-ports-temp-gauge-question.html
Transmission, manual.
NV4500 experience from one who towed somewhat heavy and often.
http://www.cumminsforum.com/forum/94-98-powertrain/858610-making-switch-nv4500-my-auto-sale-5.html#post9346913
http://www.cumminsforum.com/forum/98-5-02-powertrain/41978-nv5600-fso6406a-6-speed-fuller.html
https://www.facebook.com/RAMforFuller?_fb_noscript=1
http://www.cumminsforum.com/forum/94-98-powertrain/578541-5-6-speed-tranny-swap.html
Turbo.
The official turbo manual from Holset.
http://myholsetturbo.com/manuals/HX30_32_35_38_40_GW.pdf
HX35 rebuild and upgrade to HX35/40 hybrid.
http://www.cumminsforum.com/forum/94-98-performance-parts-discussion/613816-bae-62mm-hx35-upgrade-rebuild.html
The Saab Link Forums - View Single Post - Let the games begin :)
Turbocharger FAQ
http://www.cumminsforum.com/forum/94-98-non-powertrain/44106-turbo-timer.html
http://www.cumminsforum.com/forum/94-98-non-powertrain/487087-turbo-timer.html
Vacuum hose under hood repair.
http://www.cumminsforum.com/forum/94-98-non-powertrain/1560346-vacume-hose-melted.html
Vacuum pump.
http://www.cumminsforum.com/forum/94-98-non-powertrain/1175689-all-your-vacuum-pump-questions-answered.html
http://dodgeram.info/tsb/recalls/720.htm (Vacuum check valve revised)
VIN number information.
http://www.compnine.com/vid.php?vin=+ (This will often give a free build sheet. Sometimes it wants to be paid first.)
How to read the vehicle identification number VIN on your Ram truck
http://www.cumminsforum.com/forum/94-98-non-powertrain/1021954-where-get-build-sheet.html
Wait to start light.
http://www.cumminsforum.com/forum/94-98-non-powertrain/1445929-wait-start-light-blinking.html
Windows, side, rear, and windshield.
http://www.cumminsforum.com/forum/94-98-non-powertrain/115755-window-tint-removal.html
http://www.cumminsforum.com/forum/94-98-non-powertrain/266155-window-tint-removal.html
http://www.cumminsforum.com/forum/94-98-non-powertrain/352018-sliding-window-fix.html
http://www.cumminsforum.com/forum/94-98-non-powertrain/1132650-power-sliding-back-glass.html
http://www.cumminsforum.com/forum/94-98-non-powertrain/194132-removing-rear-window.html
http://www.cumminsforum.com/forum/94-98-non-powertrain/912682-leaking-rear-window.html
http://www.cumminsforum.com/forum/94-98-non-powertrain/487654-how-remove-reinstall-ext-cab-side-windows.html
Reactions: Lwt
Reserved in case of future needs.
Reactions: Steveo412
Reserved in case of future needs. (I needed 3 huge blocks of space so far.)
