I'm having slow response out of my 4WD unit (takes awhile to engage) and dealer suggested rebuilding the vac pump - before I do that, I decided to check those cheesy vac lines for leaks.
Starting right out of the pump - I pull about 24/25 mmHg
At the firewall - same
Coming into actuator - 19
So, is that enough of a drop to be causing my problems?
Also, is 25 sufficient pump vac?
BTW - this is on a 2000 Ram 2500 4x4 w/ 165,000 miles on it.
Cruise and HVAC work fine.
Banned
That should be more than enough to operate it. I'd suspect the actuator first....they are far more problematic than the vacuum pumps.
Vacuum good.
Reactions: bunchgrass
That whole actuator setup is pretty vulnerable as it sits. Not a lot of protection from "stuff" hitting it and the associated switch wires/vac lines etc. If you get into some deep snow/mud etc .....
Anyway, my problem was with a slow actuation of 4wd after shifting. Found this out the hard way while pulling a loaded trailer up an icy hill. Dropped it into 4H as my rears started to slip - no go. Pretty quickly I was starting to slide backwards (and jack knife the trailer) so moved it into 4L and everything was honky-dory. It was a little cold, maybe about 5F but the pickup was had been driven for a couple of hours and was undoubtedly warmed up transfer case fluids.
After screwing around with all the vac crap it seems that the problem has disappeared - I hate when that happens!
19 should be enough, but you could have leaks any where along the line, or even a faulty switch (on top of TC) that leaks or does not operate properly.
get a hand operated vacuum pump and hook it to the diff actuator and see if it will hold a vacuum, if it does not that will be the reason for slow 4x4 engaugement
