Well other than being illegal..as long as it is Ultra-Low Sulfur 15PPM you should be fine.
Red diesel used to be Low Sulfur 500PPM...but I have since heard that pretty much all diesel is now Ultra-Low 15PPM just the red is tax free. So if it is Ultra-Low you should be fine...not worth it IMO in getting caught with it. Find out what the sulfur content is on the fuel and go from there. The new 6.7 is supposed to run only Ultra-Low....but then again if you remove the DPF and emissions stuff then might be good for Low Sulfur since from what I have read that is one of the main reasons for Ultra Low. Hope this helps :thumbsup.
Red Diesel use to be High Sulfer Diesel 500ppm or higher or it may have been 1500ppm or lower i can not remember the number anymore. But before ULSD was introduce to us we had two choices. LSD or HSD which was non highway use diesel(red dye).Well other than being illegal..as long as it is Ultra-Low Sulfur 15PPM you should be fine.
If yall filtered it through a 2 micron filter and the filters where changed on a regular basis that would make a huge difference on the life of the Fuel system.We have a 12,000 gal diesel tank at work so we can fill our trucks(Border Patrol) and since we are the "G" we get red dye fuel at a deep discount rate. We have had good luck with all of our 04,05,06 trucks, but the 07 and especially the 08 Fords that we have have had injector problems, and we are now required to fill up at the local gas station with ULS diesel if were driving a 07 or 08 truck.
This of course could just be a fluke in a few trucks, and maybe a little bit of sludge in the tanks, but just my .02 worth.
For what its worth, I've filled up 3 times with LS diesel thru my 6.7L when I couldn't find ULS and I never had a problem.
If you fill up a bunch of 1 gallon plastic milk jugs (or some other clear container) and leave them in the sun for a few days it will bleach the dye out. Not exactly a high volume method but it does work...What about a filter for the red dye ?
Well I maybe I look at it the wrong way but isn't it a fine for taking the dpf and converter off and 5% tint on the windows and doing 80 in a 55. Its all in how bad you want it i guess.
