Im getting ready to do a frontend overhaul and was curious if any of you run urethane control arm bushings or sould i use moog stock replacements.. If so where could i find such a thing..:$:
The easiest way I've found to do it when there is no access to a torch is to take a holesaw and cut most of the rubber bushing out. Then you can take an air chisel and knock the rest of it out easily.Can somebody tell me how to push the old bushings out of the metal sleeve. I do not have access to a torch. is there a tool for this job. I have the bushings.
