Does he have a tuner on it?A friend of mine asked if his 6.7 would run ok if his throttle valve was unplugged?
Okay. I went and looked him up according to his signature he has the edge. He will need to keep it plugged in, but he can remove the butterfly flapper from inside. I believe if he unhooks it he will get a code. Not too sure on the edge thou.Yes, he's a member here but his internet is down his name is drt086.7
See I knew someone would chime in that was more familiar with the edge than me.Take out the flapper or the gear. But you must leave the motor plugged in. If he unplugs the EGR tell him NOT to clear codes. Works better without clearing the code.
