i will in fact be attending the Dyno show but only as a single. mechanic was backed up.
so we will get to see what the big single will do. you can take your best guess, i did buy some dyno tires and wheels. alluminum rims and 265 75 r16 cooper tires.
You just made my point there. I’m not disagreeing with you that some things might be a little bit better than others, but a lot of the claims made on the side of an expensive bottle of liquid are pure BS. It’s just something that sounds good to read that gets people to buy expensive products. Everything today that meets the spec/standard for your intended use, is satisfactory, no matter the brand, end of story. Personally, I would love to see proven dyno results showing a notable difference, proving xyz is worth the price. But, that’s also all relative. To you in your mind no matter what it’s worth it with just claims you read on the side of the bottle. To me not so much.
so Mishimoto claiming a drop in temperature-20 degrees is hokus pokus??? what about their clainm that you can run their coolant in a diesel truck for 750,000 miles before a change is necessary!!!! are they lying???? I think not. I can afford the best and will continue to buy the best. but thats just me!
good luck with your Kmart oil and filter and well see how long your engine lasts.
hey man,
honestly would love to see a coolant last 750k miles with degradation in our systems/rust ect. if we had such miracle tonics and snake oils you would think government would come regulate them 🤣
mishi 100% has better products though lol them and fluidyne were pretty good
hey man,
yes if government got involved Mishimoto would go the way of the Tucker???? I will use it till it gets shut down.....if ever. I simply like the fact that it is non toxic and full synthetic. if you ever need to drain it pull the plug and let it run out on the ground. Not more expensive trips to mechanic of Jiffy lube just to be raped to drain your toxic antifreeze!
Most of the highest hp vp trucks had top feed injectors. They are pretty sweet. I'm not sure if monster pump mike even makes them anymore but there's other companies making something similar.
Well according to DAP I need a bigger fass to feed injectors for 1000hp. They recommended the 250 I am going with the 290. Never leave anything to chance.
When tranny is done and pump upgraded I'll buy fass from DAP.
I have a message into Weston at Infinite Performance about his crosstubes, big ones. It is bothering me having the DDP tubes in my setup. I want nothing to do with any of their parts. Hopefully He'll have a giant set for me!
There is a certain VP guy that does 1000+hp and he uses crazy carls. FYI.
Maybe you just were the anomaly, it happens. I have had bad surveys ive done every great once in a while. Not afraid to admit that on a public forum Every manufacturer has a bad day or product period, we are imperfect and cant do good work 100% of the time. What you said was the key though. Customer service. What is a vendor willing to do to make it right. Also there are people that dont know how to do anything but complain.
When i screw up on a property survey they receive a sincere apology and i fix it on my dime. So it should be with all vendors!!!! IMHO!
That's the issue they aren't willing to do anything just said nope we don't do that. Well I have your crappy packaging right here to show you did. They refused to even consider anything I didn't even want a full refund just a small partial to live with it and they gave me the big middle fingers. Crazy Carl is a total D-bag in my opinion.
361 - 380 of 395 Posts
A forum community dedicated to all things Cummins Diesel! Originally founded for owners and enthusiasts of Cummins powered Dodge pickups, the Cummins Forum has expanded to include ALL Cummins Engine applications! Come join the discussion about reviews, drivetrain swaps, turbos, modifications, classifieds, builds, troubleshooting, maintenance, and more!
