1 - 20 of 305 Posts
2000 Dodge Truck 4x4 Automatic
For all who want to see what it takes to make power with a VP truck here is the combination of parts i have accumulated over a number of years. Hopefully you can gain some insight after looking over what I have put together to make alot of power. Not bragging simply sharing!
Compounds VS Racing Billet 80mmx117mm compressor 96mmx88mm turbine T6 1.32 under
S369 SX-E From Crazy Carl's.
Crazy Carl's piping kit.
Infinite Performance 6x.020 Comp. Injectors
Edge Drag Comp Hot
Fass 150
Banks High Ram
Snow WM VC 50 Stage 2 2 20 GPH Nozzles.
Mishimoto Intercooler
Stainless Diesel Exhaust Manifold With 45 mm External wastegate.
Scheid Stage 2 VP44(coming in June)
.093 Scheid Injector Lines
Dynomite 750hp+ crosstubes
Hamilton 103lb springs
Hamilton Rods
Arp rod bolts
Arp 625 headstuds
Arp XL Mainstuds
Gorilla Girdle
Mahle .40 over Pistons ceramic coated and delipped
Mishimoto 179 degree thermostat
Fleece Coolant bypass
5 in drop pipe and exhaust.
S and B Cold Air Intake
Power Bastards High Output Alternator
Colt Stage 4 Cam and Tappets
Autometer Z series gauges, trans, boost 100psi, pyrometer-never see over 1000, exhaust pressure
Power Driven Diesel 5 layer boost hoses/boots
Optima Dual Red Top Batts
Power Driven Disel Battery hold downs(does not help performance)LOL!
HPS 5 Layer coolant hoses
Keating Billet freeze plugs
Keating Billet valve cover
Orings in block
MLS Head gasket
G & R billet tappet cover.
DAP Billet gear case cover.
HIWOW BLACK TURBO BLANKET coated with cool it thermo tech
Exhaust Manifold blanket, see brand in picture.
Exhaust downpipe wrap. see amazon for brand. Engineered not chinese junk
5 inch exhaust, straight through muffler with dimples. Loudest exhaust ive ever heard. Impressive to hear!!!.
I think thats it????? I could be forgetting something??? Trans obviously has to be built to handle that!!!
Dyno sheet?
Track times?
Its coming!!!! Dyno Competition in July here. Trying to make it to that.
Dyno sheet?
Track times?
I realise this list is moot without numbers because all one can do is speculate.....................or guess what they would be.
So i will be posting dyno numbers soon. Truck goes into shop June 6th for Scheid Stage 2 upgrade. After that is done i am hitting the dyno. I found a shop in Tacoma that will run me. Just have to make appointment.
Patience please.......................you will get your numbers, then we can have a real discussion about VP 44 power capabilities or lack thereof!!! Sound good?????
Rear Admiral Rickard Onmi
2018 Ram 3500 CCLBSRW
never seen "ultimate" and "vp44" in the same title, or sentence
That's not entirely true, it usually just also includes two other words like "p7100" and "swap"
@Got Horsepower looking forward to seeing the dyno results, i miss my 02. Part of me wishes i had kept it to keep playing with it and done a P7100 swap on her, but for me my trucks are work trucks and not play things. Maybe one of these days i'll get to build a toy truck
Well we'll see won't we!!!!
Well as of yesterday my truck became a play truck. I will no longer be using it for work as my father retired and I bought his survey crew rig which is all setup with work box and tonneau(I dont know how to spell this LOL!) cover to protect equipment.
Would be better if you had several dyno runs, throughout the build to see what each piece or collection added and did, but i don't think anyone ever complains about seeing results
Discussion Starter · #9 ·
Agreed!!! Its going to be alot of fun. Going to make sure and video the whole experience!!!
Discussion Starter · #11 · (Edited)
Here is what a single turbo 850 hp vp 44 truck looks and sounds like!!! I fully expect to be at least to this level???
He is running a 71.75 mm single and edge tuning, Sound Familiar????? And Water Methanol!!! Scheid Stage 2 VP.
Most of the highest hp vp trucks had top feed injectors. They are pretty sweet. I'm not sure if monster pump mike even makes them anymore but there's other companies making something similar.
Discussion Starter · #15 ·
annihilated a fast street car tonight...........from the stop light..........i booosted to only 10lbs to keep from spinning tires.
it was comical watching hi shift gears and not be able to over take me and once the midrange power took over it was sianara. he backed way off. that was fun. wrx sti or something similar. pulled way ahead.!!!!
Discussion Starter · #17 ·
Hey rhamilton........I replaced alternator and tensioner witn new belt hoping it would fix tC problem And shift into OD.......... that would be a big fat no! So transmission specialist in Algona is getting cal for diagnostic. hopefully it is just TC and OD selonoid or other electronics. If not I've got plans for real trans.
Sonnax intermediate shaft. 6 pinion OD . Firepunk competition rebuild kit. Rebuild TC or new unit. Unless you all have ideas????. Remember I've got billet in and out, 220psi VB, all race clutches. Well see once it's tore down.
I'll accept any any all suggestions!!!!
Oh and got horsepower is not completely inept at repairs.....I did alternator, tensioner and serpentine belt myself. Took a few hours. I had to have my wife pull on breaker bar to get belt seated.....LOL. she did good!!!!
Check out the BD noise canceler it may fix the OD issue
1 - 20 of 305 Posts
