In the REVO intructions, it list the following under injection timing See option#4 below:
"Injection Timing:
# 0 - Default
# 1 - Stock
# 2 - for stock injectors
# 3 - for aftermarket Injectors ( less timing advance than # 2 )
# 4 - for fuel economy ( more timing advance than level # 2 )"
Option# 4 is listed for "fuel economy", I thought this was the wild setting, only to be used for aftermarket turbo/injectors?
However, if you look in the new Smarty S06 manual, on pg 17, it list the following under injection timing:
"Injection Timing
The Timing selection can be programmed 1 (stock), 2 (advanced), 3 (moderate) or 4 (wild)."
Which is correct? Can the #4 injection timing setting be safely used on a stock truck with stock tranny? I have a modified fuel system, no problem there.
Thanks for info ahead of time, guys!
"Injection Timing:
# 0 - Default
# 1 - Stock
"Injection Timing
