1 - 15 of 15 Posts
Has anyone heard of using a bottle of two cycle oil in every tank full of diesel, to lube the fuel back up?? just wondering if this would help.
I DONT BELIEVE IT!
I've ran it for the last 12k every tank no problems shes alot quiter sp? And helped with the mpgs also :thumbsup:thumbsup
Chuck you beat me to it!! :lol3:
Just remember 1 oz of oil to every gallon of fuel.
is it ok to run with the aridog or do you just have to change the filter more often
i ran it as well but 2 cycle is more expensive than just plain ol sulfur substitute which is the reason guys put 2 stroke in there trucks in the first place. it is quieter though!
Two cycle is just for the VP-44 guys... it can quiet your engine like biodiesel does but why would you want that? it can also cost you mpg's (every truck reacts differently in mileage) I personally run it in every tank. I've heard things about injector tips... but have never seen any hard facts.
it wont hurt "Your truck" but I don't really see it helping much either. unless you swapped to an early 24 Valve.
Mopar1973Man.Com
It not hurting my MPG nor my performance... I'm up to 21.7 to 23.3 MPG which is a 5-6 MPG gain from stock when I bought the truck... At todays price for fuel I'm not complaining one bit... Check out the sig...:lol3:
boost under 5? hehe..why would one want to do that? JK
Mopar1973Man.Com
Just what I need a wise arse...:rof
Being serious... More boost means more fuel... More fuel means more pyro... So there is 2 gauges you want to keep low...:w:
i know i know...i was kiddin. but can the rule be atleast 10 lbs?? jk
1 - 15 of 15 Posts
