I'm getting ready to put my motor back in the truck. It's been built from the ground up, from the crank to the valves, so basically there will be no issues with the motor handling the power. We've done the p-pump conversion with the 5k kit, fuel will not be an issue. I'm trying to figure out what the best turbo combo would be. The truck will not be my daily driver but it will be driven on the road. I'm looking for input from those of you who are running twins with high HP or have done a build involving this. What primary/secondary are you running? I'm looking for max HP with semi decent drivability. Thanks............
