the truck is an 05 2500 with an airdog 165 smarty tnt revo arson kit III 120HP DPP nozzles 110lbs valve springs ARP 625 head studs and DR performance pressure box also has 5 inch turbo back an k&n intake and banks big ram intake horn what turbo do u recomend ? maybe a CDS custom one ?:confused013:
Id say something 66mm+. Anything smaller is going to get hot quickly with those 120s..
Might wanna start thinking about twins/compounds.
Reactions: runninlean
yeah and you will likely need to upgrade the CP3 to get full potential also.
Reactions: Gsxguy
I agree ^ :thumbsup:
it has an arson kit III on the CP3 and we use it as a dd and sometimes tow around the farm also mostly just sled pulling
Good deal. Id get a rail psi gauge if you dont already have one to make sure the cp3 is keeping up.
Billet bullet 66 if you have the funds. It is a good all around turbo that will also flow some air for the sled pulls. You can get a custom 465 made but it will be alot more coin. Or cheaper route would be a silver bullet 66. The arson kit probably won't help those stix very much.
