isnt the phat shaft a 62/65 ??if i were you id go for something like a II Phat Shaft 62/71/14. they are real nice turbos for towing
From there website The Original PhatShaft turbochargersits a 62/71/14. my buddy has one in his dually that he tows with regulary with 100hp injectors and he loves it
are you talking about the hx35/40 hybrid? i have heard good and bad about it. some people like them and others have broken the shaft whithin one month of puting them on. for the cost, they are too high imo you could spend the same ammount or less and get a better turbo that wont be as likely to break. same with the hx40's i have heard they are real easy to break shafts. just back out to quickly and cause it to surge and snap.how does the hybrid turbo work
ok tell me this. what size is the stock hx35 compressor?56mm. and what happens when you go from a 56 to a 60? the load goes up exponentially. so ya i have only heard of one hx35 breaking a shaft but i have heard of a heck of a lot more 35/40's breaking shafts. i read just the other night i gie broke one within a month of buying it and puting it on...explain that one to me. i dont know what he did or what caused it to break but i know they are more fragile that the 35 because there is more load on a shaft with 60mm compressor than there ever would have been with a 56mm.the 35/40 will break a shaft about as fast as a hx35 will break a shaft...how many broken 35's you seen?? it uses the 35 shaft and machines slightly to fit a 40's wheel on it. long as your machinist isnt an idiot and cuts into the shaft too deep, it should be fine.
the hybrid swaps the hx35 compressor housing and wheel off, for an hx40 compressor housing and wheel (NOT THE SHAFT!!!) to you swap a 56 wheel for a 60 wheel. basically building a 60/60/12. i run mine hard every day and no probs...hell turbolvr is running 3 of them in compound triplets!!! :shock: hes using 58 wheels though.
BTW: hybrids can easily be upgraded to compound twins using the stock/ht3b kit. it will all bolt up exactly the same only you will have even more flow available...
negative. for compound twins you want 1 small and 1 that is twice its size. 2:1 ratio is the ideal compound twin ratio. so mathematically 3 identical turbo's having 2 on top both feeding off fresh air and both reducing into one on the bottom to re-compress the air to even higher pressures is a perfect 2:1 ratio. and yes, hes running 3 hybrids, says spool up is like stock, and he hits high boost pretty fast and holds those boost levels letting off better than twins do. said his next project was either gonna be triple 62's or triple he351'sok tell me this. what size is the stock hx35 compressor?56mm. and what happens when you go from a 56 to a 60? the load goes up exponentially. so ya i have only heard of one hx35 breaking a shaft but i have heard of a heck of a lot more 35/40's breaking shafts. i read just the other night i gie broke one within a month of buying it and puting it on...explain that one to me. i dont know what he did or what caused it to break but i know they are more fragile that the 35 because there is more load on a shaft with 60mm compressor than there ever would have been with a 56mm.
and ask turbolovr how much more stress there is on the shaft when you put a bigger compressor wheel on it. i have heard of people puting titanium shafts in and not breaking them mabe he is runing those. and is he runing 3 hx35/40's? i think you need two smaller and one biger just like twins...but i dont know much about tripples.
ya i know a good ammount about twins. i want to build a he351 or just my stocker for now above an ht3b and later s475. but i guess i just never put the connection together that twins had a 2:1 ratio and it makes sense that tripples would have the same.negative. for compound twins you want 1 small and 1 that is twice its size. 2:1 ratio is the ideal compound twin ratio. so mathematically 3 identical turbo's having 2 on top both feeding off fresh air and both reducing into one on the bottom to re-compress the air to even higher pressures is a perfect 2:1 ratio. and yes, hes running 3 hybrids, says spool up is like stock, and he hits high boost pretty fast and holds those boost levels letting off better than twins do. said his next project was either gonna be triple 62's or triple he351's
ya thats what i was thinking for now because im cheap at the moment. and i called banks about their exhaust housing and they want 600$+ for it! :shock: i was like forget that. ya the hx is tough i know people that have run the h3ll out of them with no problems and i have heard the hx35 over 3b is good for about 600 and spools like stock but where the 35 runs out the 3b keeps pulling.I'd do stock over ht3b or stock over s475. cheaper in the long run and that stock charger is very flexible...you can change turbine housings for more fuel to reach higher boost levels, can change the turbine wheel to several diff wheels, and can change compressor side to make a hybrid pretty easy too. a lot of kits available to mod the hx35.
