Smells like Bananas
So I got that code yesterday. I have the Smarty on there turned up pretty high, Level #9, timing #4, Torque #4, and Rail #3. I also have the Fleece controller on there. Is the code from the Fleece boost controller?
Yep. There are others on here with the same code.
Smells like Bananas
Yep as in it is because of the fleece?
Yah the fleece. It seemed to go away without the fleece.
Yea i had that code also, took the fleece of and bam code free :headbang: I do miss the fleece controler though, i like the smoke i can make with it :(
Matt
When did you get the code? Under full acc?
well i got that code and i dont have a smarty or fleece yet ... so i guess i got a problem but everything is running fine and dont seem different so i dont kno whats up
Smells like Bananas
Matt
Once I got it just leaving the house and never got above 30mph. Couple of times just on start up. Now I just have the controller set in the center and it seems to be all fine at the moment but I will keep you posted.
