1 - 20 of 33 Posts
I know I'm missing some, I would like to keep this as accurate as possible. If you have not doubt in your mind and can even back it up, let me know the specs to the ones I'm missing and I'll add them.
Borg Warner
S200
Turbine Wheel
61.5/69.5, 64/74
Comp Wheel
56/80--------58lbs/min
59/80--------61lbs/min
Housings
T3- .55, .70, .76, .85
S300
Turbine Wheel
65/xx, 68/76, 71/80, 73/80
Comp Wheel
57/83--------61lbs/min
60/84.5------68lbs/min
62/88--------72lbs/min
63/87
64/92.5
66/91.5------76lbs/min
71/105.5-----86lbs/min
Housings
T3- .55, .70, .85
T4- .83, 0.88, 0.91, 1.0, 1.10
K31
Turbine Wheel
74/83
Comp Wheel
71/100-------95/bs/min
Housings
T3- .76
T4- .85, 1.0, 1.10
S400
Turbine Wheel
74/83, 77/87, 80/87, 82/87, 82/92, 88/96
Comp Wheel
63.5/91.4----75lbs/min
66/91.4------
71/100-------89lbs/min
75/100-------100lbs/min
76/107-------104lbs/min
78/110
80/116-------120lbs/min
83/119
88/xx
91/xx
Housings
T4- .90, 1.0, 1.1
T6- .90, 1.10, 1.25, 1.32, 1.51
S500
Turbine Wheel
99/110
Comp Wheel
80/xxx
86/xxx
88/120-------145lbs/min
91/120-------155lbs/min
95/131.5-----160lbs/min
98/xxx
Housings
T6- .85, 1.0, 1.15, 1.45, 1.60
Holset
H1C&WH1C
Turbine Wheel
52/65.5
Comp Wheel
45/xx
50/xx
52/xx
54/xx
56/xx
Housings
T3- 22cm, 16cm, xx
HX30
Turbine Wheel
58/70
Comp Wheel
44/73--------45lbs/min
Housings
T3- 6cm
HY35
Turbine Wheel
58/65
Comp Wheel
54/78
Housings
T3- 9cm
HX35
Turbine Wheel
58/70
Comp Wheel
54/78
54/83
56/83--------52lbs/min
60/86--------65lbs/min
62/86
Housings
T3- 12cm, 14cm, 16cm
HX40
Turbine Wheel
64/76
Comp Wheel
58/83
60/83
62/86
Housings
T3- 16cm, 18cm
T4- 16cm, 17cm, 18cm, 19cm, 21cm
HE341
Turbine Wheel
58/65
Comp Wheel
54/xx(?78?)
Housings
T3- 9cm
HE351
Turbine Wheel
58/65
Comp Wheel
60/86-------65lbs/min
Housings
T3- 9cm
HX50
Turbine Wheel
xx/xx
Comp Wheel
62/99
66/99
67.5/99
Housings
xxxx
HX52
Turbine Wheel
70/84
Comp Wheel
64/99
66/99
67.5/99
71/99
Housings
T4I- 16cm, 25cm
HX55
Turbine Wheel
73/xx, 77/86, 80/86
Comp Wheel
66/98
67/99
65/100
72/xxx
Housings
T6- 19cm, 22cm, 25cm
HT3B
Turbine Wheel
86/97
Comp Wheel
73.5/109
Housings
T6- 23cm, 26cm, 32cm
HX60
Turbine Wheel
86/97, 90/97
Comp Wheel
76/102
80/112
Housings
T6- 23cm
HT4B
Turbine Wheel
88/118
Comp Wheel
83/127
88/139
Housings
T6- 41cm
T6i- 26,28
HC5A
Turbine Wheel
xxx/xxx
Comp Wheel
87.5/127
88/139
Housings
T6- 41cm
HX82
Turbine Wheel
94/126
Comp Wheel
82/140
Housings
T6- 22cm, 25cm, 32cm, 36cm, 41cm, 48cm
Garrett
GT35
Turbine Wheel
62/68
Comp Wheel
61.5/82------67lbs/min
62.5/82.5----75lbs/min(GTX)
Housings
T3- .63, .82, 1.06
T4- .63, .82, 1.06
GT37
Turbine Wheel
64/72.5
Comp Wheel
55/76-------50lbs/min
59/82-------56lbs/min
61.5/82-----67lbs/min
63.5/88-----68lbs/min
65/88-------71lbs/min
68/94-------80lbs/min
Housings
T3- .89, .99, 1.11
T4- 1.12
GT40
Turbine Wheel
68/77
Comp Wheel
63.5/88------68lbs/min
65/88--------71lbs/min
68/94--------80lbs/min
Housings
T4- .85, .95, 1.06, 1.19, 1.34
GT42
Turbine Wheel
75/82
Comp Wheel
70/94--------84lbs/min
70.5/94------98lbs/min(GTX)
75/102-------96lbs/min
76/102-------114lbs/min(GTX)
Housings
T4- 1.01, 1.15, 1.28, 1.44
T6- 1.01, 1.15, 1.28
TV4502
Turbine Wheel
78.5/85.5
Comp Wheel
65.5/91
Housings
T6- 1.22
GT45
Turbine Wheel
80/87
Comp Wheel
80/108------112lbs/min
80/108------127lbs/min(GTX)
Housings
GT47
Turbine Wheel
84/93
Comp Wheel
88/118------140lbs/min
Housings
T6- .96, 1.08, 1.23, 1.39
GT50
Turbine Wheel
91/99
Comp Wheel
81.5/118
Housings
TV8401
Turbine Wheel
97/108
Comp Wheel
84/117
Housings
T6- 1.23
TV8403
Turbine Wheel
101.5/111.5
Comp Wheel
88.36/116.84
Housings
T6- 1.23, 1.39
GT55
Turbine Wheel
102/111.5
Comp Wheel
84/123
88/118------165lbs/min(GTX)
89/118.5----145lbs/min
91/133------153lbs/min
91/133------167lbs/min(GTX)
94/133------160lbs/min
94/133------181lbs/min(GTX)
106/141-----185lbs/min
Housings
T6- 1.0, 1.18, 1.24
GT60
Turbine Wheel
118/129.5
Comp Wheel
Housings
T6- 1.25
Western WA President
H1C and WH1C
8 blade compressors that can be either:
45mm, 52mm, 54mm, or 56mm inducers.
the turbine side is identical and wheels are interchangeable with the hx35. housings differ slightly by bolt count on the back.. 2 less bolts. Far less efficient turbos than the hx35 that replaced it, commonly found on first gen trucks.
the intercooled first gens had a larger compressor wheel than the non intercooled version.
dunno if you wanna add that to your list or not... :confused013:
Reactions: Capt. Slow
Mule Barn Proprietor
H1C and WH1C
Never heard of a 45mm....have owned a few 50mms :confused013:
Sent from the NAFWG executive office
they are more common than you would think..
one of the turbos that you can find on a 4BT cummins. compressor and turbine size for the 4bt really depend on the purpose the motor was built for.
22cm^2 non gated turbine housing comes with the 45mm compressor.
as for the 50mm good catch, forgot that one :thumbsup:
What other turbo would these turbo specs be equal to or close to. Garrett/AiResearch TV8102, 1.23 A/R T6 turbine scroll.
Intake Major: 108mm
Intake Minor: 78.5mm
Exhaust Major: 111mm
Exhaust Minor: 97mm
Intake Exducer: 2.75" ID, 3.5" OD, Hose style
Intake Inducer: 4.5" ID, 5" OD, Hose style
Exhaust outlet: 5" V-band
The exducer on the 466 is 91.4mm you can also add the 464 which is 63.5/91.4 and flows 75lb/min. Also you have a .90 listed in the T6 housing. There are .90, 1.0 and 1.1 in T4.
vvv SOME PEOPLE'S KIDS vvv
S300's have a T4 .91 twin scroll non gated housing, very common
Also a .88 single scroll, .83 divided gated and non-gated, but I don't think there is a .85 in a T4. And if I recall, the 60mm s300 wheel flows 68lb/min.
Anyone
So does anyone have a turbo that I can compare the to for the specs I gave, I got my hands on the turbo and was thinking of using it
Discussion Starter #12
Got 'em! :thumbsup:
President of the 509
HT4B also has a 26cm^2 divided T6 turbine housing option
And 28, but aren't they T6i?
Discussion Starter #18
I saw an HX83 on an 800hp QSK19 in a John Deere chopper. Massive turbine housing, not sure on specs
There is the 64.5 FMW wheel for S300s also
The 1.15 GT42 turbine housing is wastegated
.83 T4 S300 comes in short and long outlet non gated, and long outlet, single port gated
Send me some info on this 64.5FMW.
I found this on smedingdiesel diesel: K29-3775
K29:
Compressor - 70.9/93.9 FMW
Compressor flow over 85lb/min(I'm guessing incomplete map?)
Turbine - 82/71
1.00T4
1 - 20 of 33 Posts
