I currently have 7 x 0.011 injectors with a smeding 62/68/14. For some reason I’ve got it in my head that I want a ball bearing turbo to replace my s362. Is there anything out there that’s a full kit including coolant lines, etc? I’d like to get 550-600 horsepower. The truck is for street play and is my DD.
I eventually wanted to put an s475 as my secondary for my s362 but have decided I want to try out a BB turbo as I really, really like that sound.
I guess what I’m trying to say is I’d like to make 550-600hp with a single but not have severe turbo lag. Currently with the smeding 62/68/14 it sees 8psi at 2000rpms which is atrocious. What’s a good turbo for my injectors, that sounds great somewhat like the cheetah, less lag than I do now and will be good paired with an s475?
I looked into a ball bearing turbo a while back. Basically the answer I got was, there's not enough gain to justify changing turbos; it has been tested before.
Probably a 62/68/.7 SXE is going to be the quickest spooling turbo in that category, and I would pair it with an S475/83/1.15.
You should be 500HP+ now with your current setup, if you have an aggressive programmer.
Just go with the compounds. I run a 63/67/12 tater built turbo for a few years work ok. 2weeks ago I put a s475 under and all I can say is wow what a big difference in power and egts. My truck is a 96.
Hi, We do not offer the t51r modification to add more noise to the turbo. Its a novel idea, but I don't see how it would add any performance. For $350 you can get a lot of airflow mods that will improve spoolup and reduce EGT.
Related Threads
Cummins Diesel Forum
8.8M posts
379.6K members
Since 2005
A forum community dedicated to all things Cummins Diesel! Originally founded for owners and enthusiasts of Cummins powered Dodge pickups, the Cummins Forum has expanded to include ALL Cummins Engine applications! Come join the discussion about reviews, drivetrain swaps, turbos, modifications, classifieds, builds, troubleshooting, maintenance, and more!
