1 - 3 of 3 Posts
My 89 non-intercooled needs a turbo, the stocker is leaking oil into the intake. Would a HX40W turbo work? What turbo would work with little installation problems? :confused013:
How much time do you have when you see oil in the intake?
an hx 40 would work you just need a 4 inch down pipe, an hx35 would bolt rite up
hey-hey!!!,
And by that he means the T3 exhaust housing and drain line are the same. Needs an oil line adapter( or 2nd Gen oil line ), and *SOMETHING* to mate the compressor outlet to the intake crossover. It will also need the 3" intake from the airfilter adapted to the 4" turbo inlet...I'm thinking a fernco adapter and a bit of 3" exhaust pipe for starters.
cheers,
Douglas
1 - 3 of 3 Posts
