1 - 12 of 12 Posts
Just joined this site and it is pretty cool .....
My question is what would be the " best " turbo for a set of DDP 90hp injectors and Delivery Valves & #100 Fuel Plate . I also have Water/methanol injection, but not installed yet.Thinkin of a 62/12/14 or somthing ....
I dont tow very much and the truck is used for mainly daily driving and some racin........ thanks guys!!
Engine has Stock head bolts and gasket.
Dodge Ram 4x4 SLT -95. Leer Bed Cab, DSS, 2.5 " leveling kit ,Ride-rite air springs, Sky Jackers ,S&B intake,4" exhaust, Bd Diesel Exhaust Brake, 60 lbs Exhaust valve springs, Tg switch, Rebuild ATrans. , Boost/EGT Gauges, 3gs/AFC Springs ,Fp #100, DDP HFDV/ 90 hp injectors... ..........
From Finland
I have no complaints with my PS62/14 and will help w egt's.
I have almost the same set up you do, and I installed an HTT 62/71/13 and lovin it. I have been towing way over 12k with it. the EGT's dont get to high once she spools up.
Good luck on your decision and let us know how it goes.
Sooner or later your going to scatter the head, and its going to be down.
What size dv's are you running?
DDP Part 042DV´s......are they close to 191´s. ??
Check out smokindiesels build thread hes got a lot of info in there
1 - 12 of 12 Posts
