if your saying your hearing a noise when you let off real fast, that's known as "turbo bark" and whats happening is you have all this exhaust energy driving the turbo. That in turn has the compressor wheel compressing air and sending it through the intercooler and then into the engine. When you let off the throttle quickly you no longer have the exhaust energy driving the turbo, but you have all that pressurized air on the compressor side. It is looking for the easiest way out. The easiest way out isn't to continue on through the intercooler and to the engine, but to try and come back through the turbo. This causes the compressor wheel to slow dramatically which can hurt either the wheel or the shaft if its done over and over.
