It will spool much slower than your HX35, won't light up till about 1900. Power will suffer below this point and smoke will be harder to control in the bottom and midrange. Shouldn't have a problem towing in Florida with that charger. They can be had new for $650 so don't get screwed.
It definitely has a T4 turbine flange so you'll need an adapter to your stock T3 manifold. Also 95% chance it has a 3rd gen compressor outlet so you'll have to fab up a pipe to the intercooler. You will need a 4'' downpipe to connect to the turbine outlet, which is probably a john deere marmon flange. Lastly, the stock oil drain won't work so you'll need to cut the flange off the old one and connect a 7/8'' oil line to the drain fitting in the block or get a flexible metal one online.
