1 - 2 of 2 Posts
Has anyone succesfully removed and reinstalled this actuator from the turbo. I am getting u101c after having to replace the compressor section of my turbo (don't ask). I have checked all the wiring and I can't find an issue. I am thinking that there is something up with the actuator since I loosened it to the point I had coolant pouring out and then retightened it. Any Help would be greatly appreciated.
yes, i just pulled mine and re-installed. You need to drain the coolant before you pull the actuator. Once pulled you'll need to do a pre-alignment, install it, then perform the synchronization. as far as I know this can only be done with a StarScan or similar software. I had no codes once complete.
regardless, I've completely removed, disassembled, cleaned and reinstalled my turbo 2X with no codes.
1 - 2 of 2 Posts
