well i am gathering the parts i am going to need to make more hp.i am looking at a #10 fuel plate and 75-100hp injectors. that should be making around 350-400 hp so my question is what size turbine housing should i put on the stock hx35? 12cm-14cm-16cm?i will also be adding a 60mm compressor housing with a 6 blade impeller.
also i have an exhaust brake on the truck. will i be able to keep it, or will i have to build an adapter?
