101 - 110 of 110 Posts
Discussion Starter #102
Same. The more he fixes, the better at it he’ll get too. Benefits all of us.
Couldn’t fit the ticket? Maybe show them shop bill? Saying you are trying to get it fixed
Nah I went to court and told them I’m emissions exempt and pre emissions and it got dropped.
the cops was still an ass though
Discussion Starter #103
Mat emailed back with a new set of tunes, the truck should be done today so I’ll flash and s is what it looks like
Discussion Starter #105
To hell with the pigs. Those "tickets" are garbage anyway.
I wouldn’t go as far to say pigs, they have a job to do and he may not understand diesels and emissions, he learned his lesson. I’d rather have them out there than no one out there
Fuel filter delete. That is the return block from your CP3 & relief valve that normally is integral on the filter housing that was deleted
Discussion Starter #107
Back for another question here,
With my fuel and the way the truck is set up it’s hard it keep smoke down at low rpms, I’m looking into 2 options.
1 have my old turbo re built and run that.
2 do a compound set up with my phatshaft 64 over a s475, has anyone ran a set up like this and do you guys think it would work good?
If you have no turbo down low to clean up boost, adding a larger secondary won’t help. If that’s your problem.
Discussion Starter #109
So Matt sent some tunes, they were okay I asked him to adjust rail pressure and injection timing a little and it runs flawless.
As well as pulling the muffler off I’ve dropped EGTS 200-300 degrees so I’d say it’s good, it goes to show how much good tuning does,
As well my high idle dosent work and I’m kinda pissed about that but other than that Matt fixed the problem
Good to hear. Shitty about the high idle. Glad you’ve got a tune your happy with. Did he just adjust for the mistaken cp3?
Edit: sorry reread. He adjusted the Tune he sent for the mistaken cp3. I get it
