Like to have some advice.do I have to update my clutch to run a tune for about 40 or 50 more horsepower. Like to do enough to do the deletes.looking at the raceme tuner.jack
If its a good 50hp tune then yes you will most likely need to upgrade your clutch. Better tuning options are also available.Like to have some advice.do I have to update my clutch to run a tune for about 40 or 50 more horsepower. Like to do enough to do the deletes.looking at the raceme tuner.jack
If the OP has a heavy foot, I would have to completely disagree.You should hold 50hp increase fine with stock clutch.
Two totally different animals. Trans DMF and TQ from the 6.7.Maybe the g56 clutch doesn’t hold up as well the nv5600 clutch? I ran the piss out of my 05 nv5600 for a few years running smarty s06 on tnt-r sw#7 on stock clutch. Turbo let out before the clutch ever did. Never upgraded the clutch till after doing a rebuild when the turbo went.
