1 - 10 of 10 Posts
Front end sway bar link kit for 04 by tuff country doesn't match up to the existing bracket. I've been told to use part number 30929. what is it I can't find anything about this part by tuff country?
Yeah not seeing that P/N listed on the site either. When you say it doesn't match up to the existing bracket, what exactly are you talking about, the sway bar or the axle mount? Also, are you running dual steering stabilizers? If they don't work here is another one you might look at:
SuspensionMAXX :: MAXX Links - Heavy Duty Sway Bar End Links
How much, if any, lift do you have?
Wouldn't see that as an issue since they are adjustable, and it says will work with 0-6" of lift.
I bought the same end links when I had my 06 and I put a 4" lift on and they went on just fine.:confused013:
I was under the impression the MAXX links were only good up to 3-4" lift. Wanted to get those to mount up a sway bar behind mine.
Right and wrong lol, they are in the ones listed (for 0-3")but they will custom make a set to fit whatever lift height you have if you give them a call.
Great, thanks for the info. Sorry to thread jack here BTW.
Discussion Starter · #9 ·
Tuff Country sway bar end link kit problem solved
So Here is the deal. On most applications this particular kit will bolt right on no problem. Except on some lift kit applications (tuff country) and with my 2004, it required a modification to the brackets on the axle where the end links mount. The brackets on my truck are designed to bolt the pins for the sway bar thru the top of the axle mounted bracket. Most trucks there is a side mount which makes this application a no brainer. The solution if you find yourself in this situation with the mounting point on top is to order P/N 30929 from Tuff Country. This kit comes with adapter brackets for the bottom so you can bolt on the new sway bar end links. Thanks for all that replied rendering assistance.
That's an interesting fact, very curious why AAM would have had a variation like that. Good write up though and hopefully it will help out someone else who may be in the same scenario.
1 - 10 of 10 Posts
