1 - 4 of 4 Posts
:thumbsup: First off I love my tst this is my 3rd CR truck all 3 ended up with a TST powermax
with that said my current stack is power pup/Extreme with my TST
I will need more fuel fairly soon and dont know if adding the MP-8, or Crazy Lary and EZ would be the best!!
Thanks
which TST powermax do you have? Im running the powermax r49, it has rail pressure adjustments on it to increase fuel, also has tt05 that fully fuels at 24psi and tt03 that fully fuels at 12psi. with it on standard power setting and rail pressure setting on 9 it will double pressure off the line. mine also has timing adjustments on it.
Me too^^!
Most will turn off the rail pressure feature, and run an MP8. with the bully dog set on Tow and torque managment off. My friends 03 with twins, 40hp injectors and this setup on the 03 twin program makes over 800HP.
Mine I run 4p/4tq/4rp with bullydog on tow and twin 03 programer 55psi boost
running the R39 thinking of upgradeing to the new PDA but dont know yet
1 - 4 of 4 Posts
