Truck has had some hard start problems since I bought it. The lift pump went out and I replaced it. It started good for a while but sometimes still having hard start issues and I have to manually pump the lift pump and crank her a lot to get her started. Sometimes she starts then dies right away then its really hard to start. after sitting 3 weeks it was really hard to start yesterday and ran good untill about 2000 rpms, over that she was shaky and rough. This morning it will not start only cough a few times. The batteries are fully charged and I have the block heater plugged in but its over 40 degrees. If I loosen the bleed valve over the fuel filter and pump it it bubbles for a little while then pure fuel runs out. if i crack the first 3 injection pump lines and crank it then i get a little squirt here and there.......Im thinking the fuel filter is stopped up. Does this sound right?
