truck wont idle or run
461 Views 3 Replies 2 Participants Last post by  CummewfwnsSoer04
truck is an 03 ram 2500 with 130000
today i got into truck to go to work and it would not start
when i crank it up it idles really rough then shuts off
rpms jump around and it just dies
any help would be great
thanks
1 - 4 of 4 Posts
· Banned
number of things could be the problem. no fuel pressure, clogged injectors, clogged fuel filter, lift pump going out, fuel pump going out, ummm.... anybody else want to chime in.
by the way how long does it run before it shuts down.
truck has clean fuel filter, it also has a fass on it. i can hear it running so i dnt think its that
runs for about 3-10 seconds maybe 15 then shuts off
put the programmer on it. had a perm. code that said something like comntrol module/ not programmed. then i returned it back to stock and it hasnt thrown the code again
· Banned
hmmm.... thats a mystery. Is the programmer showing any other codes? try maybe removing the negative battery cables on both batteries for a couple minutes and see what it does.
1 - 4 of 4 Posts
