1 - 11 of 11 Posts
i came outside to let my truck warm up. fired right up. let it warm up a good while since i havent drove it in a few days. 30 minutes later i go to leave and i reved it twice to 1500 rpms cause i love my new exhaust. after the second rev it died. tried to start it and it would just turn over. then i had to give it pedal to start. held it at 1k rpms for a few seconds. sounded fine and everything. let off the pedal and would die right away. then tried again and it still is happening. what is causing this?
VP of the dry side
Have you messed with anything lately?
On Cummins forum instead of working or doing homework
How cold was it when the truck died?
Cummins Nut
Idle screw back out?
You blew it up, I'll come pick it up from you.
wheres the idle screw at? the motor was well warmed up when it happened. and i havent messed with anything. i was maybe thinking the lift pump pooped out?
idle screws didnt back out. checked for both
adjust the idle up and see what it did read my post im having the same issue.
You live in a cold area? Got a 5speed? sometimes when you don't let it warm up good it dies switching gears, been inpatient few times and had that happen as your leaving your street.. -15f
Oops didn't finish reading, didn't see that it was firing back up rough.. nvm
1 - 11 of 11 Posts
