Here's the storyline up to now.
CEL came on while headed home. Shut off truck in driveway and hooked up scanner to get codes. No communication between scanner and truck. Tried the key 3 times for codes and still nothing. Truck cranked but wouldn't start.
Figuring my ECM was out - again, I replaced it but no difference.
Finally found 3 sets of wires bad. Wires to crankshaft sensor and vistronic fan were both void of insulation just back of the plugs on the engine side. All wires for both plugs, at a glance, looked like a single 8ga wire with no insulation. Also found wires going to a/c sensor (high side I think) also had been rubbing. Although the insulation was rubbed to the point the wires would short out, these were at least still intact. All wires were spliced/repaired.
Throughout all this, I've had several DTCs and C Codes. I won't list them here as I no longer have DTCs and the only C Codes are unlikely unrelated to my problem. This was all on another thread where I thought my ECM was shot. See the other thread if you like.
https://www.cumminsforum.com/forum/3rd-gen-powertrain/2478179-my-computer-shot-again-new-post.html
Right now, I'm sitting with a truck that will start but only runs for a second or two and shuts down. I don't know if it's been this way from the start but I noticed something particular today. With the key off and going directly to start, the truck will start and die. If I try to start it again (going directly from RUN to Start) the truck will only crank. No start. I have to turn the key OFF and back to start in order to get it to actually start. In addition, if I go from off to on, wait a few seconds before turning to start, I only get crank. It appears any delay going from off to start will keep it from starting.
So there I am. No trouble codes but big trouble. No truck means no work. If I can't find what's wrong with my truck soon - really soon - I'm going to be forced to find a shop to take it to. Diesel mechanics are real hard to find around me. I'm certain this is an electrical problem but I can't find any more frayed/worn wires. Fuses all check out.
