first time using a forum, i hope people are still active
i have a 1989 dodge ram ( not sure what how to know if its 89.5. says in the side of my door it was manufactured may of 89) 2500 with a 24 valve. i purchased it about a week ago knowing it had some transmission issue but the transmission issue stopped all of a sudden
anyway , i wanted to use my truck 2 days ago. i turned it on and noticed the idle was higher than my dad’s 05 ram , so i saw there was a screw on the throttle cable thing so i backed it out a little expecting the idle speed to drop a little. nothing happened so returned it approximately where it was before. i sat there and just looked around in the engine bay & then i pulled the throttle cable a little bit to hear it. i pulled it very slightly and the rpm went up , i assume it was around 3k then went back down , i rushed to the drivers seat and turned it off . i saw that the dash had a check engine light so i scanned it .
the codes i got were p1698 ( fault it companion module ) & p0606 ( ECM/PCM processor )
i left it and came inside to look them up
i later went and turned it on again and it did little revs by its self and when i slightly tapped the throttle it jumped to about 3.2k and turned it off quick fearing it’ll go over redline.
today i was taking a look at it again , turned on again & same thing happed . sometimes i get 3 codes , sometimes i get 2; p0606 ( ECM/PCM processor ) and p1689 ( CAN bus failure [ no comm between CM551 and VP44 module] )
the previous owner told me the owner before him changed the vp44 pump , and well the pump doesnt look very old
i’d really appreciate any help , thankyou if read all of that
