help
ok my truck cut off at a stop light today i pulled over in a parking lot would turn over but not crank i let it set for a minute and i cranked i reved it up a few times and it died again then i waited a minute and cranked it up agian this time i let it set it was fine drove it all the way home its only done this 3 or 4 times and its getting worse ihave no idea what it could be please any help is appreciated
it does this also going down the road dies and misses then cuts back on
Check your shut-off solenoid on the back of the pump. Sometimes that wire (should be white) gets loose and will cause the truck to shut off. It was pretty bad on mine when I had a leak and it was dripping right on that wire so it kept slipping off. That would be the first thing I would check.
· 1ST GEN
Check the connection on the power wire to the fuel shutoff solenoid. I have seen that terminal spread out from age and have a loose connection. It will not fall of. It just doesn't make a connection.
I merged your other thread into this one. That is why you have the same answer twice.
Reactions: bmpmoss
thanks for the replys is this selnoid close to the KSB selenoid
my truck was doing something a little bit like that, i had a pin hole in my fuel line and it would suck a little air sometimes
