My truck is just pissing oil everywhere looks like coming from in front of the fuel filter any ideas??? Its on a hook headed to the dealership
· Red Rider
2022 RAM 5500 Tradesman Crew Cab & Chassis 4X4
Perhaps a failed oil sending unit ??????
I hope your ready to pay for it!!!
The dealership will be more than happy to void your warranty and then fix it at your expense. :S:
Should have looked at it yourself or had it towed to your house.
If its not too late get it back!!!! And fix it yourself if you have the means to do so!! Or fix it in the dealerships parking lot!!! that what I would do.
Good luck with this but I am curious what the issue is
The dealership here or should I say my tech is cool and I will have no problems getting it fixed
this might be the same thing that happened to me, here is a rounf "freeze plug" thing on the drivers side of the engine block oil was coming from there on mine and what happened was the ccv |(crank case vent) filter was clogged up and it build pressure, well of course it has to blow out somewhere so it came out of the freeze plug. if this is the case tell them to fix the freeze plug and buy the ccv filter from them and install yourself if not they will charge you over 400$ to do a 5 min job i changed mine in the walmart parking lot down the road from the stealership. hope this helps
